Question about Siemens SpeedStream 4200 (13A4200001) Bridge
I've got a Speedstreem 4200 modem and the power light is flashing between red and green in color. Other than that, it appears to be working properly. Is it going out on me?
  • 382 Answers
No the alternating flashes mean it's in reset/programming mode. go into the interface and set it up properly.
Posted on Sep 06, 2010
Why isn't it powering up and all lights are staying on?
Check all the cables and make sure that they are plugged in tightly. After that I can't help you without more information.
May 11, 2015 | Siemens Speedstream 4200 Modem
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Wont connect. power light is red. wireless light is green. i have a 2701hg-b 2 wire. i ve tried diconnecting, resetting, but the gateway remains the same. what do i do?
I've got the same issue, 2 wire claims that whrn the power light is red, the modem is bad and must be replaced. I would try and power the modem from another circuit before replacing. I am replacing mine today
Jun 24, 2009 | AT&T High Speed DSL Modem
Siemens Speedstreem 4100 Modem Not Working
Try restarting the modem by either turning off the power button, or plugging out the modem power.
If the internet still frequently disconnects, it is most likely your ISP's (internet service provider) problem. Call them up with this issue, and they should either re-activate your internet for you, or give you a replacement modem for free.
Hope this helps, please rate and leave a comment ^_^
Jun 18, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
My sentinel cctv when powered on all the indicator lights flash on and off and there is a clicking sound. Any idea what the problem is?
hello sunrisepmp, i bought the model lorex l19wd and i have some problems with the remote connection. i can`t view my cameras remotely...
Locally everything work perfect but when i try to establish a remote connection, the lorex client 7.0 tell me that the connection is sucessfully but i can`t see any image.
I`ve a linksys wrt54G router and a speedstreem 4200 modem, i connect the system directly to the modem, also i create an DDNS Account (i had a doubt about the mac adress that you have to put at the form, i filled with the mac of the system) and i configured the system with the information that you sent me to my email, like the manual said...
Thank You
Mar 11, 2009 | Home Security
Siemens Speedstreem 4100 ethernet adsl Modem red power light
Hi frisko.... you will have to Reset your router, there would be a small hole behind the router, you can ***** a pen or pin , for 5 sec, an then check, you may have to reconfigre the router from. 192.168.1.1,
Jul 24, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Placing Sppedstream Modem 4200 in bridge mode
http://192.168.254.254/brgmode.html ...or if they have the gay firmware >.> go to http://speedstream/brgmode.html then click apply....now set your router to log in with your user information with a PPOE login...if your like me and using the dlg-4500 just go to setup and do internet wizard to set up easily...then your ready to go... it can take up to 10 minutes for your router to configure so give it time..and if it doesn't seem like it's working in that time...try cycling your power then check again...and if still not working, do a hard reset (hold reset till lights alternat from green to red) to reset to factor default (do it for your router too becfause it will still be set to sign into your isp for you)
Jun 14, 2008 | Siemens SpeedStream 4200 (13A4200001)...
I have a siemens speedstreem 4200 modem. I am getting ADSL 2 next week, so i updated the firmware for the siemens website. since that was done, no more internet connection. i have checked everything i can...
It sounds like U are trying to use a dialup modem with a DSL driver. Uninstall the modem via the control panel - system and reinstall with orginal driver.
May 23, 2008 | Siemens Computers & Internet
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
680 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
