Question about Blueair 501 Air Purifier
My dog peed in my Blue Air 603 air cleaner, nice huh? We were able to clean it up nicely except for the tray at the bottom, on the side of the unit. So the question is, how the heck to I open this to clean that tray out? There are only 4 visible screws on the top of the unit to remove the sides.
My ionic pro ca500 has the blue light on but also is making a intermittent sizzling sound, I have wiped the blades, the clean light is not on.
What does the blue light mean? I had 4 Ionic breeze air cleaners, ionizer wires are broken. I was thinking about buying the Ionic Pro cleaners, but have no input about how well they work.
Dec 02, 2013 | Ionic Pro CA500 Air Purifier
How do I change the filter on the Kenmore 335?
According to the Owners Manual, here's what you need to do,
1.Turn the air cleaner OFF and unplug it from the power outlet.
2. Carefully lay the unit down on a flat surface with the Front Grille facing up.
3. Gently push in on Release Buttons on both sides of the unit, pull Front Grille out and away.
4. Remove and discard used HEPA filter.
5. Remove any plastic protective wrapping and from the new HEPA filter.
6. Set new HEPA filter into the air cleaner.
7. Install the Front Grille by engaging its tabs into the bottom slots on the unit. Then swing grille up and gently push in top to snap into place.
8.Turn the Air Cleaner upright and plug it into an outlet for
operation.
Hope this helped you. Please let me know. Thanks
May 04, 2011 | Kenmore 335 CADR Air Purifier
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
I have the Flair Air Purifier. Everything except the light seems to be working. When i push the button, the fan jumps into high mode for a couple of hours as it is supposed to, but I don't notice any...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse just for the ozone part it is marked F21 on the same board, it is soldered in the board, it is a black round fuse marked 400ma 250v on some models
Aug 21, 2010 | Ecoquest Flair Air Purifier
Makes buzzing sound after cleaning blades
I keep the blades clean. Really clean. I'm a smoker, and you would not believe the crud that accumulates on those "blades"... <g>
First, I spray the blades with "PurplePower" cleaner/degreaser (from AutoZone), then I wipe them down with a sponge, then rinse with hot water. then dry them with compressed air (I have a compressor...).
FWIW, "Windex" works pretty good too, but... the degreaser really works well on the cigarette "residue"..
Second, there are two long wires inside that also have to be cleaned, periodically.
If your unit has the "pull-tab" cleaner, use it. One of my units has it. The other two don't.
On the ones that don't have the built-in cleaner, I stick a chopstick in through the rear vents, and CAREFULLY rub it against the sides of those wires, which "scrapes" the "white crud" off of the wires. Take your time. You will likely have to "change locations" several times in order to access the full length of both wires.
NOTE: those wires are fairly durable, but BE CAREFUL with them.
Either way, after cleaning the wires, I then "blow" the unit clean with compressed air.
Voila! No more buzzing. Until the next time the wires get "crudded up".
Mar 12, 2010 | Ionic Pro CA500 Air Purifier
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have a Trion Max 5 1400. when the air is flowing past, I turn on the power switch and both lights come on, then go right off. We have had the unit for awhile, and have had the power module repaired...
Read the owner's manual for troubleshooting, it has a lot of information.
https://www.trioniaq.com/getfile2.aspx?fileid=9024
http://www.trionparts.com/trion-max-5-1400-air-cleaner-parts.html
Check the ionization wires are there, one may be broken and touching the ground plates.
Also check to see if the wires have a growth touching the ground plates. If so, clean the grids and wires; let it dry. Water and electricity don't play nice.
Jan 20, 2010 | Air Purifiers
Clean light won't go off
Evil little critter, huh? Find the sensor and clean it.. Seems it is the boss onn that unit.. Good Luck, Ned
Sep 16, 2009 | Air Purifiers
Can't clean Ionic Pro CA-500 inside?
This unit is a pain in the @$$ to disassemble but it CAN be done. The way I always look at it: Someone ASSEMBLED it.
Remove the four screws on the bottom stand followed by two screws on the bottom side of the unit. Then remove the tiny little screws up each side that hold the grill together (you will need a precision screwdriver).
Carefully pull apart- don't force it.
One half comes off (clean that half) in bathtub. The other half does not come off-vacuum that half out and use q-tips.
When re-assembling, watch for two things: First the wire cleaner (that slides) runs on a track on each half- pull it out a little to best allow for fitting. Second, there are little tabs at the top that fit under the control panel-watch for those.
email me at originalpairadice@yahoo.com if any problems.
Oct 19, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Blueair 501 Air Purifier Logo
41 people viewed this question
Top Blueair Air Purifiers Experts
Are you a Blueair Air Purifier Expert? Answer questions, earn points and help others
