Question about Vizio VX32LHDTV10A 32 in. LCD HDTV
My Vizio VX32LHDTV10A acts like the buttons are stuck, but they are not. This is true whether I hit mute, change the volume, change the component, etc. It also does not matter if I use the remote or the buttons on the side of the unit. For example, if I try to turn the volume up, it will turn ALL the way up. If I try to switch from wide screen to normal, it will flicker through all the views without stopping. Help!
    Top Expert:
  • Vizio Master
  • 74,887 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Posted on Jul 27, 2017
5 Suggested Answers
SOURCE: only vizio light on
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
Posted on Feb 20, 2009
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
budmrtn
  • 11361 Answers
SOURCE: I need to attach a
They are Metric screw either M4, M5 or M6, you can get them at HD or LOWES for about 35 cents each. The length of the screw should be about 3/8 inch beyond the screw hole.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 01, 2010
Volume on Samsung stuck at zero
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
http://electro-medical.blogspot.com/
Aug 25, 2016 | Samsung Televison & Video
GV42L HDTV picture ok but no sound.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Feb 25, 2016 | Vizio GV42L 42 in. LCD Television
My vizio tv does not have audio
Jul 10, 2015 | Vizio M422i-B1 42-Inch 1080p Smart LED TV
Cant use menu
You may need a different remote. Is this a universal remote? Some of them have these common problems. Mine, for instance, doesn't use the OK button at all; instead, the Menu button counts as the OK button.
Try navigating the menu with the TV's volume / channel buttons (the ones on the TV itself, not on the remote). This usually works. Try that until you get a different remote.
Jan 29, 2018 | Vizio VX32LHDTV10A 32 in. LCD HDTV
I have lost my remote and the kids pushed the side buttons on the TV to raise the volume but instead changed the channel. Now I can't get back to the channel that works with my AT&T uverse box.
Instead of changing the channels, press the "INPUT" button on the side of the TV slowly and repeatedly. The TV will cycle through all of the available external inputs one of which will be for your Uverse box. If this doesn't work, try switching to channel 3 or 4. I can't say which will be correct as it depends how the equipment is setup.
Hope this helps.
Regards,
BElectric
Jan 07, 2011 | Vizio VX32LHDTV10A 32 in. LCD HDTV
I have a new vizio 37", just got it, On some stations the volume is so low, I can't hear it. I have cable tv, the volume on the cable box is way up where it says sterio;when the volume is on 100 % it still...
On remote hit tv button hold set up until it flashes twice. Hit 11758 it will flash 4 times hit set up to lock. Now hit tv button and the volume should work on set.. Hope that works
Jan 30, 2010 | Vizio L37 Television
Vizio VX32LHDTV10A 32 in. LCD HDTV Logo
64 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
