Question about Dryers
Like many others I have having problems in fitting a new belt to a Simpson Sirocco 350. Who ever designed this machine did not want it repaired. I fix a lot of appliances over the years but this one has me beat. I have found that by turning the back cover 90 deg I can get into the motor and pully but can't get the tension for the drum to turn . I feel I have not fed the Motor /pully combination correctly . Have you a diagram to follow.Thanks Harry
  • cramer441 Aug 24, 2010
    Well I fixed the problem myself. This is how to do it .Remove the covers and fan belt on the back . Place the unit so the motor is on the bottom left hand corner. the back cover can now be moved 90 deg to the left and remove the wire from the 2 clips holding the cable . Now remove the spring that goes from the motor to the rib on the drier case. The motor can now be swung down. With the drum belt around the drum making sure the groved side of the belt against the drum towards the back. Feed the belt around the pullykeeping to the right of it and then onto the motor drive. Replace the spring . Now replace the cover to the correct position replacing the cable in their clips and open the front and guide the rim of the drum into its position. now put some screws in the back cover. Check that the drum is driven when the motor is turned by hand. Place the drier on its face and finish the job . Hope this helps. Harry
Thanks Harry. This problem was driving me to a state of profane fury! Without your advice, my driver would have been added to landfill. Cheers. Alan
Posted on Apr 22, 2011
The centre rear pulley is locked causing the belt to break. Simpson sirocco 500 dryer
And you tell us this WHY . ? replace the pulley with a new one
Mar 09, 2018 | Dryers
Is it a big job to replace the heater element on the Simpson Sirocco 350 dryer?
It won't be the element unless a wire from it is grounding against the casing. You most likely have some sort of issue with the home breaker.
Mar 15, 2014 | Kenmore 500 6952 Dryer
Simpson Sirocco 350 Dryer cuts out after 5 minutes I am told it is the heat sensor attached to the red button inside the door but not sure how to access the sensor to replace it.
Its probably NOT the sensor causing the problem. Have you checked the fan belt, that its not broken, come off the pulley or stretched? Put your hand over the airvent outlet at the back after it has been running a few minutes, if there is a lot of hot air coming out, then belt is ok. If not, replace the fanbelt with a new one, and problem will be solved. The sensor pops out because of overheating - usually because either the fan belt is broken or stretched, or the lint filter is blocked. Hope this helps!
Jun 04, 2010 | Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Mar 21, 2009 | Dryers
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Oct 08, 2008 | Maytag 7.0 Cu. Ft. Electric Dryer
Simpson sirocco 350 clothes drier
Yes fixed with prayers I found the restart safety switch and am now dring merrily,.Paste
Sep 05, 2008 | Dryers
Dryers Logo
492 people viewed this question
Top Dryers Experts
