Question about Sylvania SST4322 32" TV
I have a Sylvania sst4324s tv and would like external speakers. The owners manual says the red & white audio output jacks are 2W 8ohms ea. Do I need an amplifier with speakers to make these work or just speakers? If an amplifier is needed, any suggestions as to what would work best?
  • 490 Answers
At 2 watts, it would run very small speakers without an amp, but I suspect you would be more happy with a home theater amp. There are a number of surprisingly inexpensive models with DVD players in the same unit. Here is an example:
http://www.overstock.com/Electronics/Coby-DVD765-Home-Theater-System/3981690/product.html
Hopes this helps:)
Posted on Aug 23, 2010
Testimonial: "Thanks for the help farmerbear!"
How do I connect an external speaker
There are a couple different ways.you ca go
On the back of your tv you could have either,
1 - Optical Audio output
2 - RCA jack audio output ( Red and White color ports )
or
3 - 1/4 inch auido jack. audio out
When you find the jack that matches up to the deice you want to connect hook them up ad then go into your TV settings menu and turn on External speakers
Mar 04, 2015 | Televison & Video
Sound
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Apr 14, 2014 | Sceptre X322BV HD 32 inch Class Television...
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
Process of elimination... First and foremost, you didn't tell us what model Bravia TV... the RX-V model has so many plausible connections to that TV, even if there is no optical on the TV.
Would you please verify TV model, and check exact Yamaha Model, I looked for the model you state and couldn't find it.
Generally speaking... red/white is the oldest way to connect to your receiver... are you connected to the correct input? and how is the receiver to send to the tv? What is the input... cable, dvd, etc... then you select "input" then on the receiver you select OUTPUT only is labeled on the receiver. Now... let's say cable box goes into the TV, and you are wondering why no audio.. that is because you are using an INPUT on the tv white/red to the receiver.. cannot do that, won't work, only HDMI can talk both way on some HDMI input/output. The only only only way output from a TV can be done is HDMI arc ...(look up ARC) and then enable it on receiver too.... or a optical from tv to receiver, or lastly output red/white on the tv... and in some you don't have any but may have a headphone jack that you'd buy a headphone jack to red/white ... take the headphone jack plug that in.. that is output, make the input any input on the receiver and you will select that input on the remote and it'll work.
Gimme more infor and I can get you better answers :)
Feb 11, 2018 | Televison & Video
I connected a speaker bar directly to my new LG TV. The speakers came with two audio cables ( red & white) and one video cable (yellow). I connected the red & white cables to both devices - red...
You can only get the television to recognize the external audio when connecting to its audio OUTPUT. If it does not say OUTPUT on the television where you've connected the red and white cables between it and the spear bar it is not going to work. You'll have to connect all your devices to the speaker bar with red and white cables and to the television with a yellow or green, blue, and red cable for video.
Aug 29, 2011 | Audio Players & Recorders
I just bought a Panasonic TV model TC L37E3 and I do not know how to coneect my external speakers. Please help me as I feel very frustrated by now. Carlos
Carlos, I just bought an LCD tv too. To connect external speakers to mine I had to buy some high end 5 channel pc speakers and connect them through the headphone jack(I know how stupid that sounds considering we spend $1000.00 on a TV and thats my only option for external speakers.I looked at your owners manual and didn't see a headphone jack though so you may have to opt for speakers that plug in with through the usb port. Some new tvs won't support external speakers unless you use complete home theater surround sound system which will connect through the rca cables (red,white)
May 22, 2011 | Panasonic Televison & Video
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
How do I conect external radio/speakers to my lg 42lh40-ua
There are many options here. Most HDTVs today have analog audio and digital audio output jacks. You can use RCA audio cables or a 3.5mm connector, whichever your HDTV has to connect the analog stereo output of the TV to any number of devices such as a stereo/amp which has speakers attached. You could also connect an FM transmitter to the TV and send the audio wirelessly to a nearby FM radio, boombox, portable etc. Most HDTVs today have a digital audio output, typically optical, which uses a digital audio cable ($15) to connect to a surround sound receiver. You can also connect the stereo analog output jack on the TV to a 2.4GHz transmitter and receiver speaker combo to get wireless audio outside, in a swimming pool and so forth, all around the house using wireless speakers. These setups usually cost around $150 or so. Look for the jack on the TV labeled AUDIO OUT and see if it is the white and red 2 jack ports or the smaller 3.5mm single jack port. Adapter cables are available at Radio Shack for around $10 should you need them. So you see the options are almost endless.
Aug 17, 2010 | LG 42LH40 LCD TV
Lost Owners Manual - Can't get Audio Out Jacks to Work
the manual is avild here http://www.manualsparadise.com/pages/P061220/P94561532.html
but look and see if there is a switch on the back of the tv that sayes external speakers, if so us that and you book self speaker will work, also check in the menu under audio for this same setting, if none of these are there look at the back again this might be a audio out jack that is made to go into a amplifier
hope this gets you on the right track
Feb 08, 2008 | Zenith Z27H41D 27" TV
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
Sylvania SST4322 32" TV Logo
126 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
