Question about Mitsubishi Televison & Video
Tv displays msg. Tv will turn off in a few seconds, Check air flow is not blocked. How do I clean the air filter?
Burn your tv
Posted on Jun 15, 2008
Nissan stays on for a few second then shuts off. all lights in dash are on.
Could be the spark plug wires, the mass air flow sensor, the fuel pump, or the fuel filter. Many things to check. Please be more specific. The car starts and the motor runs for a few seconds? Thank you.
Dec 19, 2015 | Nissan Cars & Trucks
Why does my window ac is set on thermastat but comes on and off to quickly
Hello friend, thanks for the post!
From my understanding your Frigidaire air conditioner is rapidly turning on and off, this could be due to restricted air flow. First, I would check to make sure the air filter is clean because a restricted air filter could cause this problem. Secondly, check to make sure nothing is blocking the air flow like drapes, blinds, or furniture. Lastly, your condenser coil could be dirty or blocked I would make sure if it installed in the window that no bushes or trees are blocking the coil. I hope this helps. -Matt
Aug 01, 2014 | Frigidaire FAC126P1 wall/window Air...
It says to Check the air flow
Open the cover. At some ends there will be 'filters', to clean the air entering the projector. If these filters are blocked with dust or lint, air flow will be blocked.
Clean any dust from these filters. Close the cover and check whether your problem is solved.
Sep 14, 2011 | Hitachi CP-X251 LCD Projector
Tv says air flow problems
ok what you have there is a faulty thernal sensor nitisubishi has issuued a bullitten to serice centers so check with local service center the repair might be covered under warennty
Jun 18, 2009 | Mitsubishi WD-Y65 65" HDTV
Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Jun 04, 2009 | Mitsubishi WD-65731 65" HDTV
Mitsubishi 56 inch dlp,screen says tv will turn off in a few seonds,air flow seems to be blocked,tv turns off and orange light comes on???? Have to push reset button to clear orange light,this is constant...
Hello!! It might be either that the tv is overheating because of the lack of air, or it may also be your ballast.
First of all I recommend you clean the fans, so the air flow won't be blocked, don't use something that mioght damage some of the boards that are inside, you can buy one of those air cans to clean computers, if that does not work, I recommend you listen closely and notice if there's a clicking sound, if so it might be the ballast.
Mar 14, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubushi 1080 HDTV has an air flow block
There is a fan in the back. Make sure that the fan is spinning and that the grille is clean. It is possible that the sensor is bad too.
Keep us posted.
Dan
Jun 06, 2008 | Televison & Video
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Televison & Video Logo
285 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
