Question about Garden
My lite switch wires hook to ceiling lite wires along with my hot wires
  • 128 Answers
Yes thsey do
Posted on Aug 23, 2010
Hunter ceiling fan/lite kit wire diagram
Blue is light and white is COMMON and BLACK is HOT
Jan 01, 2012 | Hunter Ceiling Fan Control Switch
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
I just bought a switch to control both fan speed and light control (dual switch) i hooked it up every thing worked fine. then to realize that the outlets that follow dont work. just as a clue on the...
The key seems to be that you changed wiring in the ceiling box.
I suggest you make a drawing of the wires before and after. Track the route that the Hot wire takes.
The key question is this: Does Hot wire from breaker box arrive in the ceiling box first? Or does it arrive in wall box first?
I think Hot from breaker arrives in wall box first. And from there Hot wire goes to ceiling box ... and from ceiling box the hot wire goes to other plugs in room. If this is true, you will be one wire short for installing fan control switch.
I always make a drawing of existing wires before starting, so I can put it back the way it was. It sounds like you got a good handle on which wire goes where.
We used to solve the one-wire-short problem by making a simple project bigger. Figure out which direction ceiling joist run. See if you can slide fish line from fan ceiling box over to wall. If that works. Over at the wall, chop small hole in ceiling so you can feed wire up to fish line. Pull wire over to ceiling box. Next, staple other end of wire along ceiling over to location above wall box. Chop another small hole so you can feed wire down to wall box. And then install beautiful crown molding to hide the mess, and paint the room so you need new furniture.
Oct 02, 2010 | Electrical Supplies
I need to replace my switch for speed an i dont how my wires go
mcdevito75 here, The wires in the instuctions should show what color they hook up to, now just match those wires with the switch, a small tip, hook up a dark wire from the fan motor to a dark wire on the switch, a lite color wire from the fan motor to a lite color wire on the switch as you hook up each pair or wires, cover the bare wires remaining on the fan motor and switch with tape and try the fan to check spped.
Jul 20, 2010 | Aloha Housewares (93645) Ceiling Fan
Does the red wire coming out of the ceiling go to the blue wire in the fan. i cant get the lite kit to come on
The white wire in your ceiling box is USUALLY the neutral wire. Green or bare wires are ground wires. Any other colored wires are generally hot, switched or unswitched. If changing the position of a wall switch makes a white wire hot, it is NOT a neutral wire. You need a test light, generally an inexpensive neon test light available at any hardware store, and a book on basic wiring would help. To control the fan and light separately, assuming you have not installed a wireless control, you need two switches, one for the fan and one for the light. If you do not have these, you need a wireless control unless you have a spare wire in the wall switch box or you need to be satisfied with controlling the separate functions with the pull chains. Check the ceiling box wires. Put one lead on the ground wire or, if you have steel boxes, on the box. Remove the wire nuts on the other wires, being careful not to touch any wires or touch any of the wires to each other or the side of a metal box. Touch the other lead to the other wires, one by one. If the light comes on, the wire is hot. Try the wall switch(es) on and off and see what changes. To make the fan or light work it has to be hooked up to a neutral wire (white, never hot regardless of any switch positions) and a hot wire. The same is true for the light kit. If you do not have or want two wall switches, one for the light and one for the fan, you need to identify the wire that is hot when you turn on the wall switch and hook it up to the black (fan) wire AND the blue (light)wire. You then control both with the single wall switch in conjunction with the pull chains. If you have two switches in the same wall box, and they make two different wires hot in the ceiling box, hook one to the black fan wire and one to the blue light wire. If you're set up with only one switch, and you're lucky, you may have an extra wire in the same cable from the ceiling box to the wall box, with a wire nut on each end. In that case, install a second switch for the light (or a combination switch designed to control both a fan and light). Hook the hot wire from the wall box to both switches (or the hot terminal on the combination switch) and the other two wires to the other two terminals that go to the ceiling box to feed the light and fan. Never use a light dimmer switch to control a fan or a fan speed switch to control a light. If two or more switches in different areas controlled the original fixture in the ceiling box, things can be complicated. If the same wall switch makes two different wires hot depending on it's position, for example, it's a three or four way switch. The above description also assumes the wall box is fed from the ceiling box, but the opposite may be true. There may also be wires in either box that are feeding other circuits in the house. Electricity can kill or burn down your house. If unsure of what you are doing, hire a licensed electrician. Also be aware that if you touch the leads of the test light to two wires that are both hot, the light may not come on. Always test with one lead on a ground or a wire that you are sure is a neutral wire. I recommend tuning off the power to all the circuits in the boxes that you are working on, after you have determined what the wires are, by shutting off the circuit breaker(s) or removing the fuse(s). There may be more than one circuit in a box.
Feb 12, 2010 | Hampton Bay 24002 Ceiling Fan
I have red, metal, beige, and black wires in my ceiling. how do i hook up my Glendale fan?
If you could give me the specs on this (voltage and amperage), I can begin to help. Also, I would need to know what the values of the wires in the ceiling are. Meaning...is Black or Red wire's a Hot wire or switch leg. To find this out. First turn off the circuit breaker(s) at your electrical house panel. There could be two circuits, so make sure to have a voltage tester, or a little induction voltage tester that will help determine if power is on or off. Also, turn your wall switch off designated for this fixture. Now, leaving the wall switch off. Make sure to do this with two people. Turn on the circuit breaker. Either the black or the red wire will be hot (unless there's other circuits involved, which I don't think there is). Once you determine your hot wire, write it down. And then turn on the wall switch. Now, the other wire should be hot now. This is your switch leg. The wire that will operate (on and off) your fixture. Beige is most likely your neutral wire, and will go to the white wire(s) at the fixture. And the metal wire is your ground wire, and should go to your bare copper wire inside of your fixture. So now, turn everything back off (including both your circuit breaker and wall switch). So, Hot wire goes directly to your wall switch. It might be easier to hook up your switch leg first, because then the wire left over will go to your switch. So, Hot wire hooks up to wall switch. Other wire coming from switch, hooks up to the other colored wire (switch leg). The beige wire stays at the fixture and hooks up to the white wire(s), and then the bare copper wire splices (connects) to the metal wire from the ceiling. After you have everything wired, and the fixture put back together. Here's how you test it. Leave wall switch in off position. First, turn the circuit breaker back on. If everything is fine, then you turn on the wall switch. Note: If you're able to leave the fixture in the on position prior to turning the wall switch on - do so. That's why if there's any problems, you'll be a safe distance away. And the worst that could happen is that you trip the circuit breaker. Then, you'll have to recheck everything you did, and make sure all your connections are secure. Well, Good Luck to you, and feel free to ask me any further questions you may have. Jim
Jan 22, 2010 | Hampton Bay 52 In.Carriage House II in...
Remote Control Ceiling Fan Problem
OK, first off, there have been some problems with those remote units. That said, let me tell you what the wires should be doing and you can see if that is happening.
Normally they take a "Hot Wire" and attach it to the white wire that goes to the switch. It is hooked through the switch to the black wire to bring the "Hot" back up to the light/fan. The whites in the ceiling box are the neutral. A "Hot" and a neutral are required to make anything work. The copper is a ground, or added safety. It usually is attached to the same spot as the neutral in the breaker box, so it is not a big deal. If you have a hot going to the switch which works as the off/on valve, and back up to the box. The hot and a neutral make what ever you hook it to work. Now, if you have a remote, it uses a connection at ceiling box to turn it on and off. You can have a switch to turn the whole thing off and on, but if that switch is on, the remote is just a different way to turn it off.
If you have a way for the electricity to make the big circle, it should work, unless a part some where is not letting it through. I imagine in your situation it is the remote.
If this is new, you may want to see if you can get another, and take the remote part out (Up in the fan) and replace it. You would not have to re-assemble the whole fan. I have replaced several of these lately, and even put a different kind of remote on a few.
Nov 30, 2008 | Oasis Hunter 54' Ceiling Fan
Electrical box not working
unfortunately it sounds like the main electic wire is shorted out. Not the one to your fan, but the one that provides the power supply FOR the fan. The only way i know to fix this is to get an electrician. I am certain the wire needs replacing.
Nov 29, 2008 | Hunter 52" Ceiling Fan With Light And...
Where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Nov 15, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Nov 17, 2007 | Dryers
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
