Question about Refrigerators
I own a Dometic model RM2354. It's gas, DC/AC and is 5 years old. It cools to 40 degrees on gas and AC. But when on DC, running off my truck electric (7 way at the rear bumper) the fridge only cools to 60 degrees. Any ideas for troubleshooting or repair? Drake Ambrosino 734-260-5045, drakeambrosino@comcast.net
3 Suggested Answers
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
VtToolMan
  • 704 Answers
SOURCE: Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Posted on Jul 30, 2009
NDR 1292 - Was freezing/cooling on electric, but stopped freezingcooling, tried gas but doesn't freeze or cool
Since it does not work on either AC or gas - do you have DC to the unit? I have spent many hours troubleshooting a Dometic that turned out to be a corroded DC connection.
Jul 26, 2011 | Dometic NDR 1292 Refrigerator
Dometic refrigerator model RM 2193 for RV works only in the DC and LP Gas mode. two days ago the AC mode was still working and stopped yesterday (outside temperature was about 40 degrees...
Hi and welcome to FixYa, I am Kelly
Operators manual:
http://www.gas-refrigerators.com/pdf/RM2193-manual.pdf
Parts manual:
http://www.scamptrailers.com/Portals/0/Dometic_Refrig_RM2193_PartsList.pdf
If you look at the last page of the parts list (page 10) it is showing a thermostat across the Black and white wires.
There is not a fuse that I can see. The fuse has to be external to the unit. You should be able to read continuity (resistance) of the AC heating element at the power cord with the AC switch ON.
AC Power source must be removed to perform resistance checks.
No continuity there are 2 possibile failures (Other than wiring)
1. AC heating element
2. Thermostat.
Thanks for choosing FixYa,
Kelly
Jul 22, 2011 | Dometic Refrigerators
I use a Dometic RM2193 in my pop-up camper. Can anyone tell me what temperature differential I should be able to acheive on 120VAC, propane and 12VDC? On 120VAC I was getting about a 40 degree fairenheit...
Usually from the Bottom of the refrigerator you should have minimum of 43f or colder than ambient. Should work very close to same on both gas and 110, on Dc it may not cool as good. From your description you may have an issue with ventilation. Cold air needs to flow in through the lower vent and out through the upper, if it cant, cooling efficiency is lost. Adding a fan kit can help on hot days. On gas you may have particles that fell down in the burner. Just take the cover off, take the burner screw out and blow down into burner to clean out. compressor or canned air works fine. If cleaning the burner doesn't improve it enough on gas to match electric you have to make sure your regulator on your rv has enough pressure... the fridges require 11 inches of water column.
May 03, 2017 | Dometic RM2193 Compact Refrigerator With...
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Dometic rv fridge
Your possibly getting a DC voltage interuption Your convertor can be over heating causing a temporary drop. You can chech this by turning everthing dc supplied on and watch to see if the check light comes on then. Primary is electric and if no electric then it is suppose to look for gas.
May 29, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
