Question about Craftsman Garden
Craftsman 2550 psi 2.3gpm Model 580.752052 start water flow / start motor / water flow stops no pressure
3 Suggested Answers
  • 384 Answers
SOURCE: can get no water flowing to the spray nozzle
Most likly the sliding nozzle valve is not fully down or up. I have found after the nozzle lay about for some time they get stuck from water scale. It took two persons pulling and pushing on the valve to get my to operate again. It worked for me.
Posted on Jun 11, 2009
  • 18 Answers
SOURCE: cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Posted on Jun 27, 2009
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Sears 2550 psi power washer does not have any water flow with the motor running, but has a low flow from the wand when the motor is off.
If this unit has set for that long has you have rust inthe end of the nozzle. take it of or undo the wane and soak it in CLR this will take the rust out. GOOD LUCK....
May 19, 2014 | Briggs Stratton 020273 Elite Series...
Troy bilt 2550 psi pressure washer My friend gave
Try this link. I think you'll find what you're looking for.
http://www.troybilt-gen-pw.com/owners_manual/
Nov 04, 2013 | Garden
No high pressure water coming from soap inlet
have one of these same problem last month had to pull the pump off the bottom and free up the pump then worked
Apr 15, 2013 | Craftsman 2550 MAX PSI Briggs & Stratton...
Water flows thru the pressure washer pump and out of wand, when I start the motor flow stops. I have a craftsman model # 580.752060 I've taken pump apart and there are no obstructions that I can...
Let the water run for a longer time. "Walk" the hoses, from the faucet to the pump and then to the nozzle, holding the hoses up to displace any trapped air in the lines through the pump and out the nozzle. What it sounds like is that air is reaching the pump. When it does, it cavitates, and no water can be pumped. Tighten all of your hose fittings securely. Try holding the trigger down while starting the washer. It may be easier with another person helping.
Best regards, --W/D--
Jul 08, 2011 | Craftsman 2500 PSI Briggs Stratton...
I have the Troy-bilt 2550 psi pressure washer with a Briggs & Stratton engine (model# 020337). Originally, it would start and die immediately. I took the pump apart and cleaned out the unloader valve...
I would replace the internal part of the unloader valve, it is known as the unloader seat, I can order you one it would take 2-3 days, Part number is 193972 price is $45.06. If you are interested in ordering one send me a email at justin@wmpcs.com with the information that I just gave you.
Another thing that you can check is the outlet check valve, the tube that you screw your high pressure hose onto has a valve built into it, if that valve went bad or if there is something stuck in it you would also have this problem. If you take the tube off the valve will be right where you screw that pipe onto the pump, the valve is part number 190592, price on this is $8.16.
Nov 10, 2010 | Karcher 2500 PSI Pressure Washer
Continuos pumping
Continuos pumping is associated with waterlogged
pressurized system. To correct it, do this steps.
1. Put the power line off.
2. Drain all the water inside the pressure tank by
taking off the plug at the bottom. Then replace and
close the drain plug.
3. Open the priming port plug and fill it full with water.
Replace the priming port plug.
4. Close the flow control valve to regulate water output
5. Put the power back on, and start the pump.
6, Slowly open the flow control valve until the water
stabilizes at 20 or 30 psi at the pressure gage..
7. Set the pressure switch to stop at 40 psi and
start at 20 or 30 psi.
This will solve your problem.
Oct 15, 2009 | Plumbing
My sku 509560 has begun to stop and then restart after 15 minutes or so? It them runs for 10 minutes and stops again. Is it fixable?
Yes, it can be fixed.Assuming that your water system is pressurized, take the following steps;
1. Shut the power off the lines going to the pump
motor.
opening the drain plug. After emptying the tank,
replace the drain plug.
3. Unscrew the priming port plug and fill it full with
water. And at the same time fully close the
flow control valve.
4. Put the power back on, and slowly open the
flow control valve until the water flow stabilize at
20 or 30 psi at the pressure gage. This could be
at 1/4 open or 1/3 open, depending on the water
supply at the suction point.
5. Check and set the pressure switch to be off
at 40 psi.
Aug 25, 2009 | Plumbing
Cleaning solution isn't siphoning to washer wand
Jun 23, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
350 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
