Question about Dyson Vacuums
I think i have burnt out motor. can it be repaired?
  • 694 Answers
If the motor is burnt out, it can't be repaired. Replacement is an option, but the cost of a new motor plus labor may be more than the cleaner is worth.
Posted on Aug 23, 2010
Machine was running, it quit and has not ran since. This happened last week. I did change out the switch thinking that may be the problem.
Proteam Pro Force 1500XP Bagged Upright Vacuum
Tom, the motor has probably burnt out, if you dismantle machine you could test motor directly to prove faulty or just replace machine.
Mar 31, 2016 | Proteam Pro Force 1500XP Bagged Upright...
It made real funny noise and a smell of burning, while i was using it.so i turned it off
take it to an appliance repair center as it may be a burnt out motor
get quotes first before repairs as a new unit could be cheaper
Nov 01, 2015 | Vacuums
Sebo vac grinding noise and burnt smell
Take it to your local vac shop for assessment. Sounds like a bad motor. If they are not a Sebo dealer, make sure they know that a X1 motor is not the same as an X4 motor. It should cost around $200 for the total repair . A new X4 is $799 so the repair is usually a good idea.
Jun 16, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
My vaccum is smoking help!
The motor has burnt out Cheaper to get a new unit than to have it repaired. Always make sure if you use a bag that you keep the bag clean as it requires free air flow to cool the motor.
May 26, 2013 | Vacuums
Smell of burning now no suction
Hi There, if you are talking about an upright vacuum you may have simply broken the belt that drives the roller. If you are talking about a standard barrel vacuum it would sound like you have burnt out the motor. If the motor is burnt out and it was not an expensive machine in the first place just replace it. If it was a more expensive vacuum take it in to a repairer for a quote.
May 22, 2012 | Vacuums
Hello, I was vaccuming around the house i accidently **** some water out of my dog water bowl.Now it dont want turn on?
Water and electricity don't mix, so you probably burnt out the motor. There's a possibility that a thorough cleaning with a motor cleaning spray that leaves no residue will bring it back to life, but I think you will need to replace it.
Dec 12, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I think my vacuum is even older. It's a tank type. My carpet attachment won't spin where the brush rotates.
The first thing to do is make sure the power nozzle motor is working. If it is, then check the belt by trying to spin the brush. If it spins freely, the belt is broken and needs replaced.
If the power nozzle motor is NOT running, there could be several things.
1. Make sure brush is clear and cleaned of all loose strings, cords, and other foreign matter.
2. Press reset button. Try vacuum again.
If it still doesn't run, ensure all wire connections are tight, and have no indication of arcing, i.e., blackened or burnt connections. Any such connections need replaced.
There could be a broken wire in the hose. Usually the hose will need to be replaced, but occassionally it can be repaired.
Internal wiring worn or broken. Needs repaired/replaced.
All repairs should be done by an authorized Aerus Electrolux service technician at an Aerus store. Check the phone book, or go to the following site to locate the store nearest you.
http://www.aerushome.com/storelocator/
Oct 13, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Kenmore 23613
if it smells like burnt plastic it is something wrong with the motor part, but if it is a wet dog,burnt hair gross kinda smell it cool change the bag and buy deoderizer tablet to put under bag kinda like a airfreshener. if it dont work like it used too not picken up like should something wrong
hope that helps,
Dec 29, 2007 | Kenmore 22085 Bagged Canister Vacuum
Vacuums Logo
55 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
