Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Water overflows from the detergent drawer - Whirlpool Duet 3.8 cu. ft. Front Load Washer
  • Whirlpool Master
  • 43,501 Answers
Check this tip out...
I know it is about the fabric softner, but I think that the problem with the detergent is inthere also...something is dirty and plugged up...
Fridgidaire Washing Machine Fabric Softner not going into washer
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Posted on Aug 23, 2010
Samsung washer what does in mean water stays in the detergent dispenser after a wash..cant remove the cap on drain tube..
The detergent compartments for bleach, softener, and liquid are usually siphon activated. Remove the dispenser drawer by pulling it out all the way and depressing the release tab. Remove the compartment siphon caps and check that all parts are clean and free of debris, gunk, or grime. If the problem is still present, low rinse water pressure can be a likely cause preventing the siphon from working properly. You can manually activate the siphon by re installing all caps in the drawer, hold the detergent drawer over the kitchen sink, and pour a glass of water into each compartment till it overflows, wait to see if the respectively filled compartment then drains all but approx 1 teaspoon from it's self. If so your dispenser is fine. If the cap on the drain tube is the one at the bottom behind the access door that you are trying to remove, you should only do this if there is a need such as the unit not draining the water completely from inside the basket of cloths, or if you receive a long drain error.
Apr 17, 2014 | Washing Machines
After a wash why there,s water in the detergent compartment
The detergent compartments for bleach, softener, and liquid are usually siphon activated. Remove the dispenser drawer by pulling it out all the way and depressing the release tab. Remove the compartment siphon caps and check that all parts are clean and free of debris, gunk, or grime. If the problem is still present, low rinse water pressure can be a likely cause preventing the siphon from working properly. You can manually activate the siphon by re installing all caps in the drawer, hold the detergent drawer over the kitchen sink, and pour a glass of water into each compartment till it overflows, wait to see if the respectively filled compartment then drains all but approx 1 teaspoon from it's self. If so your dispenser is fine. If the cap on the drain tube is the one at the bottom behind the access door that you are trying to remove, you should only do this if there is a need such as the unit not draining the water completely from inside the basket of cloths, or if you receive a long drain error. Pleazer Appliance...
Overflow of water from the detergent drawer
check for blockage in the water flow path. sometimes old detergent can get solidified.
Nov 08, 2013 | Washing Machines
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water overfilling in detergent tank
CHECK THE INLET HOSE UNDER THE DRAWER, PULL THE DRAWER ALL THE WAY OUT BY DEPRESSING THE MIDDLE BUTTON ON THE MIDDLE REAR OF THE DRAWER. MAKE SURE ITS NOT PLUGGED WITH DEBRIE
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH6700AWW overflows out the detergent tray opening while filling
water leaks out of the plastic box where you put the detergent/bleach/fabric softener, from the OUTSIDE of the box onto tub, drips down tub on to metal tray and into drawer. Anyone had this problem?
Nov 07, 2009 | Maytag Washing Machines
As the washer is filling with water, it overflows out of the dispenser area. it appears that the water is not getting into the machine quick enough as the dispenser fills with water.
hi there......this problem is usually caused by a build up of detergent in the hose leading from the soa disenser into the wash tub....remove the soap dispenser....check for accumulated detergent under the drawer....and in the top of the fill hose....easy removed with a little patience and warm water....
regards Sir Galahad
Aug 16, 2009 | Washing Machines
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
