Question about Ricoh Aficio 3800CMF Laser Printer
Seems to print a red or yellow line down the edge about 1 to 2mm wide, prints black fine. All toners over half full. Test page seems fine but can see red line along edge.
  • Rob2k Apr 15, 2009
    I currently own a HP Color Laser Jet CP3525n and it is brand new. For some reason or other i get a few 1-2mm lines of yellow down every page and in random places.
    Any ideas? Ive tried calibrating, resetting everything, apart from buy another toner, which isnt` cheap.
    Any help would be appreciated.
  • 95 Answers
What ever color the line is you need to replace that photoconductor unit. They can be ordered from a Ricoh dealer and come with instructions for installing.
Posted on Mar 12, 2009
Ricoh aficio c420dn wont print black
Hi, my experience with this machine is that the gear that drives the black pcu breaks or cracks. Usually caused by the pcu being too hard to turn. I always turn the developer gear in the pcu before installing it just to loosen the toner.
Mar 15, 2017 | Ricoh Aficio Office Equipment & Supplies
HP LaserJet 1020 Printer Black leaving a black line on the left side of paper. What is causing this
Lines down the page can be caused by a few different things. The most common are the toner cartridge having a defect, or the fuser being worn out. The quickest way to figure out which one is to do a "half print" test. You need to start a print job, then open the toner cover when about half the page has been printed. Check and see if the line is on the page. If it is, then the toner cartridge is to blame. If it isn't, then the fuser will be the problem. (not worth replacing the fuser on this unit)
Be careful of the toner on the page with this test...it will not be attached to the paper and will rub off easily.
Hope this was helpful
Jul 26, 2011 | HP LaserJet 1020 Printer
Print quality problems C3400n
And the problem is with the magenta drum.
Jun 22, 2009 | OKI C3400n Laser Printer
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
HP CP1215 prints a line of black dots down the centre of page. Happens with all settings on high quality paper. Same with normal paper.
Perform a half paper path test. Put the paper in the manual feed tray, print a test page, when half of paper is pulled in the printer open toner door so the printer stops. remove the toner and check print is the issue there you have trouble with your toner cartridge. Otherwise there is an issue with fuser. Mostly I think you have an issue with tonercartridge, try take it out and shake gentle
Nov 05, 2008 | HP Office Equipment & Supplies
Thought I would ask you, since u have answered Ricoh CL3500N
According to the maintenance manual, broken lines are caused by the "dithering" setting. Also there is an in depth color calibration process you can execute. Have you checked the PCU unit?
Here is the maintenance manual:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/cl3500/cl3500en.htm
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
I am getting a faint line all down the page
Most likely you have a defective black toner cartridge. Open the front shutter on the black toner and look at the drum. If you see the drum has toner on it corresponding to the line down the page, you found the problem. If you can't see anything on the drum try printing a page and then interrupting the printout while the page is still in the printer. If you see the line on the page before it goes through the fuser, (the last roller thing on the top of the printer) then it still is the toner cartridge. If it occurs only after the fuser then it, the fuser, is at fault.
Jun 29, 2008 | HP Color LaserJet 2600n Printer
C900 Colur print problems
Print a self made test page in word, a bar of bright yellow, bright cyan, bright magenta (almost pink) and black.
You might find one is completly missing, if so its a faulty toner or maybe the pull strip did not rip out correclty.
Jun 23, 2008 | Epson AcuLaser C900 Printer
Ricoh Aficio 3800CMF Laser Printer Logo
464 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
