Question about HP Office Equipment & Supplies
How do I open the back door to my printer to remove a paper jam.
  • 55 Answers
The flap covers are usually snap fitted at the back,try pulling it out softly & it will disengage.Then remove the bolcked paper
Posted on Aug 23, 2010
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
When i on the printer display show paper jam
Hi
First switch off your printer now open the door of printer and remove the paper that jam. checked any small paper pieces is there also removed...................now close the door and switch on the printer..
May 18, 2011 | Computers & Internet
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 18, 2010 | Office Equipment & Supplies
Paper is jammed in the back-- can't figure out how to get it out.
Hi
Please turn off the printer and unplug it from main power. To remove any stuck paper, you'll need to open the rear door of the printer. The back part/door can be removed. After removing this door, check for any jammed paper. Close the back door and open the front door of the printer (from where you can see and change the cartridges). Now check for any paper jammed near or under the carriage. Remove any paper jam if any. Check for small bits of paper as well.
Now turn on your printer and check.
Daniel Scott
Jun 17, 2010 | Canon MP560 All-In-One InkJet Printer
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
How do you open the printer as i have paper jammed
Hello: Most printers have a door on the back for removing paper jams. Look on the back for a compartment to open and remove jammed paper. Also check for foregin objects in the paper path .
Oct 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
How do I fix a paper jam cef for epson aculaser cxn11nf?
Diagram of doors should be above control panel of printer.
Lift ADF/Scanner up. Open door "C" just below it. Lift orange photoconductor lever up to release photoconductor. Lift photo conductor up towards you. Inspect for jammed paper and remove if necessary. Replace photoconductor, close lever and door "C".
Open door "E" on rear of printer and look for jammed paper and remove. Close door "E".
Last place to look is in paper tray. Take stack of paper out and look for paper jam. Removed as needed.
These are the three places i have had jams and you will only find the jam in one of them. Most likely it will be in back in Door E
Aug 12, 2009 | Epson ACULASER CX11NF All-In-One Printer
How can i remove the paper inside the printer
For the paper jam issue turn around the printer and open the back door to pull the paper.
and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't get the back door open to remove jammed paper. How do the levers work?
I downloaded the user guide and saw a picture illustration that showed how to open the back door of the printer.  I was then able to follow the visual directions on the printer LED to remedy the paper jam.
May 28, 2009 | HP PSC 2355 All-In-One InkJet Printer
Paper Jam - HP G85 Ink Jet Printer
You open the door from the back of the printer (turn the knobs) and the paper can be removed from the back. After removing paper jam, replace the door. It is a long door as wide and the printer, but about 2 1/2" wide.
Feb 28, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
93 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
