Question about Cycling
I need to remove the pedals of a Mongoose downhill mountain bike
  • 252 Answers
Hi Miranda
You need to purchase a pedal removal spanner(wrench). They are very thin so they can slot in between the pedal and the crank.
If this is not an option, find a 15mm spanner(wrench) and tap it onto the bit where the pedal meets the crank. Ive always found that you need a friend to sit on the bike, hold the opposite pedal at the low stroke while you undo the pedal.
**REMEMBER** pedals have the opposite to normal threads. To undo them, you need to turn them clockwise. Spray penetrating fluid onto the threads a day before you attempt to remove them. They are very difficult to remove.
Hope this helps.
Posted on Aug 24, 2010
How do I make my bike faster
pedal faster...
beside that, you need to change your gear rose for different setup as well as sprocket. that meant you will need to spend few dollars on new gears to increase your speed.
this particular model is not designed for speed, it is designed for performance, like jump, slide, concourse, slalom, gravel, downhill - all of these are difficult to achieve on other types of bike, but that one is perfect for it, therefore i would suggest - do not pursue the speed but tricks on it, you will be envy of all neighbourhood...
Oct 18, 2013 | Mongoose 20 in. Boys Axe Bike
The left pedal assembly won't stay on a Mongoose XR75 24 inch full suspension mountain bike about 1 year old. (not the pedal itself but the shaft that the pedal attaches to comes loose). Tried blue and...
mine use to do that too, try lock tight in the nut after tightin on the nut make sure you put enough and make sue its tight it works till you need to take the pedal off it worked for mine
Aug 14, 2013 | Mongoose Cycling
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
Sep 30, 2012 | Mongoose Exile 26 Men's Full-Suspension...
I have 26" Mongoose Snarl,both
A simple web search for 'remove bicycle crank' turns up numerous videos.
http://www.parktool.com/blog/repair-help has the many special tools and advice one needs to work on a bike.
Aug 21, 2011 | Mongoose Sector 26 Men's Full Suspension...
How do you tighten the chain on a Mongoose 75 mountain bike?
there is a spring tesioner but probally need to take a link or two out of chain
Feb 18, 2011 | Mongoose Exile 26 Men's Full-Suspension...
Hi im having ploblems removeing the right adapter on the pedal chainweel it is solid and will not budge.any suggestions. thanks steve.
Place the unit in a cold location , metal contracts. then put your spanner on the bike and wrap chainwheel in an old rag. Tap the spanner with a piece of wood and a hammer
Should work for you
Dec 06, 2010 | Mongoose 2008 Amasa Comp Mountain Bike
I HAVE A MGX MOUNTAIN BIKE. WERE THE PEDAL ARE
im certain that model has a 3 piece crank set up. the inner crank bearing jam nut has loosened up or the bearings themselves have gone bad.first check to see if its tight, if it is then it will require a replacement set of bearing that are a pretty standard size to all bikes and can be purchased at nearly every bike shop.
Jul 08, 2009 | Mongoose MGX Maxim Dual Suspension...
Quick shift problems for mongoose
1. oil it
2. on the back of the bike there is a place where the chain rolls and you can push it forward... take the chain off then back on.
3. make sure you pedal fast to get it off. Hope this Helps
Feb 03, 2009 | Cycling
Removal of sprocket and gears from rear tire for replacement
A special sprocket removal tool is required usually only $20 to $30 bucks at a decent bike shop.
Jan 29, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Cycling Logo
134 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
