Question about Whirlpool GEQ9858J Dryer
My dryer won't start. I hear a clicking sounds as if it is trying to engage, but nothing happens.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
5 Suggested Answers
Amigaman
  • 248 Answers
SOURCE: kenmore dryer
Check to see if ignite is glowing and then goes back out. If it does, it probably needs a set of burner coils. If it glows but doesn't go out, it probably needs a flame sensor. This is box on side of burner tube.
Posted on Nov 15, 2007
shinn8
  • 85 Answers
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
heatman101
  • 43501 Answers
SOURCE: I have a kenmore 90series dryer model #
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Posted on Aug 15, 2011
heatman101
  • 43501 Answers
SOURCE: The dryer won't start. Tried
heatman101
Posted on Sep 11, 2011
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
The dryer won't start. Tried to hard reset, but it still will not start. You can hear it clicking over, but nothing happens.
heatman101
Sep 10, 2011 | Dryers
I have a kenmore 90series dryer model # 110.60927990. Worked fine one day next day pushed start here it engage nothing happens. Tried it again same outcome like trying to start a car u hear the starter...
heatman101
Aug 15, 2011 | Kenmore Dryers
I have a Whirlpool Gold Ultimate Care II dryer. The dryer stopped working. It is getting electricity but still won't start. Any idea what the problem could be??
The first thing you need to check is if you actually have 240 Volts going into the dryer. Sometimes one half of the (dual) circuit breaker opens and only sends 120 Volts down the line. If you hear a buzzing sound when you press "start" but nothing happens, it could be a stuck motor. Or the motor could be running but the belt is broke. There are more possible scenarios, but try this first.
Jun 08, 2011 | Whirlpool Dryers
Making buzzing sound and not turning. then the buzzing sound stops and it smells like something is burning. then u will hear a clicking noise and sound will stop all together and nothing will happen unless...
The motor on your dryer has gone bad. The humming is the motor trying to start and the smell is the motor getting hot because it is not starting.
You need to replace the motor.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 09, 2010 | Kenmore Dryers
The dryer will not start when you push the switch. Have checked the plug and power at the box. It sounds like the clock on the setting is working, but nothing happens when you push the button
Try this simple test. As the door opens or closes you should hear a muffled click of a switch. If you don't hear that click when the door is just ready to close or just opens the door switch or actuating arm has failed.
Jan 22, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer Won't Start
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
75 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
