Question about Samsung Alias 2 SCH-U750 Cell Phone
Alias 2 won't charge - Samsung Alias 2 SCH-U750 Cell Phone
Alias 2 won't read micro SD card
It might just be the sd card try getting a new one if that dosn't work then try sending for a new sd reader and swap the two out.
Feb 22, 2013 | Cell Phones
My Samsung Alias 2, just purchased in december, will not turn on. Fully charged, but will not turn on
its a manufacturer probs and if u have ur warrnty active then u can ask 4 replacement or repair it 4 free in ur samsung service center... bettr fight 4a replacement
Apr 12, 2010 | Verizon Communications Samsung Alias Cell...
Can I use the Samsung alias 2 is an Internet modem
    Using Alias 2 as Modem
  1. The Alias 2 can, in fact, be used as an external modem to connect your computer to the Internet. To do this, the phone must plug into the computer via USB. The USB data cable specific for the phone is purchased separately and can be found at most any cellular phone store and eBay. Because USB is a powered connection, anytime the phone is plugged into the computer for use as a modem, it will also remain charging, so you don't have to worry about battery life while online.
    In addition to the cable, you must subscribe to a specific service through your cellular provider in order to use the Alias 2 as a modem. This plan will be a "tethering" plan and will have a separate charge each month to use it, similar to a cell phone's data plan. By signing up for this feature, your phone will be able to dial into the data network and utilize the Internet connection as a modem, allowing any connected computer to surf the Internet. Once this feature has been activated on your account the option will become available on the phone itself to enable tethering.
    At this point, you should be able to turn on tethering, connect the phone to your computer via USB cable and select the phone on your computer as an Internet connection source.
    It is important to note, however, that the Alias 2 uses a different and slightly older system on the 3G cellular network. Because of this, using the phone as an external modem will produce a slightly slower Internet connection than a traditional modem or even a newer phone would. However, as a backup solution for Internet connectivity or a travel solution, the Alias 2 will work just fine as a modem for your computer or laptop.
Apr 01, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
HP ProBook 4515s no sound
You will have to drive the sound on your system or you download it from www.hp.com/download then type in the model and the driver you want which is sound driver then when you download it run it on your system and that end the problem anything else?
Mar 06, 2010 | Computers & Internet
Where do i get a usb driver from my alias 2
The Alias 2 is not supported by the Samsung PS Suite.
Jan 13, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
My alias 2 is stuck in USB download mode. How do I
My boyfriend has a samsung convoy and his phone does this every time it dies, he fixes his taking the battery out, then he puts the battery back in, and BEFORE you turn the phone back on put the charger in and let it charge for a min or two. Then try turning the phone back on.
Jan 05, 2010 | Verizon Communications Samsung Alias Cell...
My alias won't charge
Unfotunately, this is a common problem. The first thing you should do is take it to the Verizon store(or someone else with the same charger) and ask them to try a charger. Hopefuly you can just buy the new charger. If this isn't the case, and normally it isn't, you will have to buy a new phone or dish out the 50$ for insurance if you have it. The problem is that you broke the charge port in your phone. Samsung considers this to not be under warrenty. The Verizon store cannot do anything for you. Hope this helped.
Sep 17, 2009 | Verizon Communications Samsung Alias Cell...
SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Aug 05, 2009 | Verizon Communications Samsung Alias Cell...
Samsung Alias 2 SCH-U750 Cell Phone Logo
169 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
