Question about Frigidaire Washing Machines
The door will not lock on the front loader - Frigidaire Washing Machines
    Genius:
  • 1,075 Answers
Two things are the possiable cause,1 the hook type catch on the DOOR is broke,2the main door lock is broken,this consistes of a plastic type mounting where the main door lock sits i would say this is the problem and needs replaced.please rate this answer.adrian,,,,,,,,,,,
Posted on Aug 23, 2010
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Whirlpool front loader washer door remains locked
Here is one way: http://www.youtube.com/watch?v=gSF4JS2B_U0&playnext=1&list=PLoRcTDdjR-2afhmUpe11VXBKUReLA8CAa&feature=results_video
Jan 27, 2013 | Whirlpool Washing Machines
Maytag front loader 2000 series code LF followed instructions in manual and has no power. Outlet works
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Aug 20, 2011 | Washing Machines
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
My front loader door wont lock
Believe it or not, you may be able to fix that yourself with some spray lubricant applied to the shaft of the electric lock mechanism, but you will have to remove the lock to lube where it's stuck. Then you will need to work the locking jaw back and forth till it breaks free then reinstall.
Mar 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a front loader. When I shut the door and
pin on door switch is brocken. look on top of door latch
Feb 12, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Nov 16, 2008 | Whirlpool LHW0050PQ Front Load Washer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Zanussi Front loader washing machine
is the door loose( up/down movement) could be hinge problem,or the door lock may need replacing.
Mar 20, 2008 | Washing Machines
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
