Question about Brother XL-5500 Mechanical Sewing Machine
Thread bunches up in the bobbin area and needle appears to be stuck and won't move. Almost like the thread wont come off the spool.
  • 109 Answers
Check to see if the thread coming off the spool is tangling on the spool pin or getting caught in the crack on the spool top where the thread originally comes off spool. Make sure the spool pin is pushed all the way to the right to secure your thread and then back it off slightly so the thread pulls evenly off the spool. Whenever your bobbin thread gets bunched it is usually something is wrong with the threading of the UPPER thread and vice versa. Let me know if this solves your problem.
Posted on Aug 23, 2010
STRING IS BUNCHING UP. NOT FEEDING RIGHT MAYBE
By string, I assume you meant thread ? Is it bunching up underneath the fabric you are sewing, or on top ?
If it bunches up underneath the fabric, the upper thread tension may not be right or the mechanism may be worn or need replacing. If it bunches up on top, thread guides may be catching or the needle may be damaged.
First thing, try a new needle. Damaged or dull needles can cause problems. Also try a new spool of thread, because sometimes a thread spool might have been damaged or is just bad quality. Some machines will not work well with very cheap, economy threads, so if you're using cheap thread, get better thread to try also.
Test stitch after each change you make to see if it's helped. The upper thread tension adjustment should work at any setting, but for normal sewing, should be at a middle setting.
If thread snarls up on top of the fabric, unthread the machine and check every thread guide for wear or nicks that might be catching thread.. needles can cause this also. May need to replace a guide if it's damaged, or perhaps use a file, emery cloth or sandpaper to smooth a rough spot. Rethread the machine with a new spool, set the upper tension to a medium level and try again.
If the thread bunches under the fabric, it's often the upper tension that's not right. Thorough cleaning of lint from the bobbin area should be done also, even a tiny bit of lint can be a problem in some machines. Try rethreading, try a new spool of thread, and a new needle.
If no setting on the upper tension produces a balanced, even stitch without bunching, the mechanism of the tension adjuster may be worn and need either professional adjustment or replacement.
Very rarely, you may find the bobbin tension might also need adjusting. Take out the bobbin case, you'll see the tension is controlled by a small spring which has a tiny slot screw on it. Mark the exact orientation of the screw slot now, [ marker pen or tape] so you can put it back where it was if need be. If you have to to a adjust it, you should move that screw only a tiny fraction of a turn at a time.
Check bobbin tension - pull out a foot of thread and hold the end of it , with the bobbin case dangling. Shake the case up/down like a child's toy YO YO. If the bobbin moves along in reasonably even increments with each jerk, it's likely ok. Or you can pull it along and see how hard it is to pull. If the bobbin case won't move or is hard to slide, it is too tight. If it slides on the thread freely it is too loose.
Usually. clockwise turns tightens the tension, but check to be sure. One tiny adjustment at a time, it gets a bit tedious. You have to put the bobbin back in and try a few stitches after each adjustment to see if the bunching is getting any better. If it makes no change or makes it worse, put the screw back to the original position.
If you are handy and can find a repair manual for the machine, you may be able to adjust the upper tension mechanism yourself, it should not need special tools. Often for older machines the hardest part is finding another part to replace the damaged one.
Sep 29, 2014 | Brother Sewing Machines
After 2 or 3 stitches needle gets locked with balled thread
Lint and or thread has collected behind or under the bobbin. use a q-tip (cotton) and swipe out and around the bobbin and bobbin case. Use a can of air and blow out and around the bobbin area. Remove the spool thread from the machine and rethread the spool and bobbin thread in machine.
Feb 03, 2014 | Janome Magnolia 7330 Sewing Machine
Bernina artista 180 bottom stitch bunching
bunching under the material is bird nesting is a result of loose needle thread tension thread the machine up to the point of threading the needle
pull on the thread and you should have a reasonable resistance to pulling the thread
adjust the tension until you get that then thread the needle
while you may be using the tension settings if there is a problem in the tension plates area , the tension will not get high enough regardless of the indicated setting
bobbin tension can be reasonably loose
correct tension is when both threads meet at the center of the materials being sewn
May 25, 2017 | Sewing Machines
I have a Bernina Activa 130. I tried to sew over some leather, started fine, then the needle got stuck and I stopped right away. Now, the bottom threads keeps bunching. I have re-threaded the machine, new...
You need a fatter needle. The skinny needle will not open the leather enough for a smooth flow of thread and that's why the bobbin is bunching up when the top thread is sticking. Make it easier on your machine by using an appropriate size needle while sewing leather.
Nov 04, 2013 | Bernina Activa 130
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
When trying to sew my thread is skipping stitches and then the i get a whole bunch of thread wound up together on the bottom. I have cleaned it out but it still wont work. Keep getting an E6 code.
change the needle
rethread the top thread & make sure the top thread doesn't come off the thread take up lever
make sure the bobbin is not warped
make sure there is no lint in the feed dog area
some needles & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 04, 2010 | Brother CE5000 Computerized Sewing Machine
Thread jamming under fabric
bobbins in backwards
flip it over
Dec 18, 2009 | Kenmore Sewing Machines
Singer Merritt 2430
Hi!
There could be several reasons due to which the thread keeps bunching up underneath.
It may be due to tangling of upper thread. Remove the thread completely from the machine, use correct size spool cap for the size of the thread spool, re-thread the machine, now remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please rate the solution as FixYa and revert for any clarification.
Thanks
Rylee
Apr 23, 2009 | Janome 6019QC Mechanical Sewing Machine
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Janome Sew Mini bobbin problem
Hi, Usually wrap-ups in the bobbin area are caused by the lack of tension on the top thread. The slack arm ( shinny lever that moves up and down while sewing) has to pull the loop around the bobbin case and it does so only if the tension on the top thread is sufficient to keep it from pulling more thread of the spool.
Try this: Thread the top of the machine all the way just short of the needle eye. When the presser foot is up the thread should pull through easily. Now drop the presser foot (this closes the tension discs) and pull the tread while adjusting the upper tension control.
If everything is working correctly you should feel the drag on the thread change if not something is keeping the discs from closing.
Most Janomes aren't too difficult to remove the nose cover, usually just one screw and you can get a look at the thread path. Look for thread wrapped around the mechanism.
Sorry, no easy answer but I hope this helps.
Mar 16, 2017 | Janome Sewing Machines
Brother XL-5500 Mechanical Sewing Machine Logo
219 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
