Question about Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9630A Fault codes
I purchased this model at auction for $525. Supposedly new, but open. Need to know if i should scrap it or repair.
Hung on wall, noticed the speakers kept popping. Figured a way around it would be to hook up to an amp for external sound. So i opened it up and disconnected the wires from the speakers. Kicked a fault code so i reconnected the speakers. Now when u power on hear the amps kick in, but then kick off and gives me a 11 on the TS board.
Also have had a problem with the tuner. When in Cable skips the majority of the channels, and the ones that do come in are black and white with little or no sound. When in Antenna i get about 8 channels but perfectly.
Worth the money to fix or not... Read about the speaker wires getting smashed so am going to try that today but in the mean time any help would be appreciated.
  • NattyK May 09, 2008
    Will give it a try this weekend and see what happens. Thanks for the help.
  • 72 Answers
Yea this model kinda sucks with ambilights ( one thing they wont tell it has a problem ambilights catching on fire !! no lie, there is a factory recall and modification). anyways back to question the popping noise. If u have a multimeter or can borrow one check the Ohms of the speakers they should read around 8 Ohms. But your best bet is to Change both speakers if you can find some with the same rating it will be fine. And also change the Audio Amp . On the board the the speakers plug into the big IC think its 7200 i think. Well its the biggest IC on this board. And for the Channels skipping u have a bad tuner.
Posted on May 06, 2008
The only thing I can suggest outside of taking the television to get repaired is a hail-mary firmware update. To be honest, the firmware update process is fairly complicated and lengthy. You can download the firmware and find instructions for it here.
Look on the right hand side for firmware information.
This TV is likely outside of its 1 year manufacturer's warranty so you would have to pay any and all repairs. Before deciding to do a repair you might try calling Philips. For a while they were offering a service to customers like yourself with out of warranty units. They would offer to sell you a more up to date model at a discount. I'm not sure they still do this but its worth a shot.
Hope that helps!
Jul 19, 2011 | Philips Televison & Video
Philips 50 pf9630a/37 I need a power cord for this model
The part number for the AC cord is 242207000054 and here is a site you can order it from.
You should just be able to get a AC cord off of a computer as they use the same type or even purchase one from Radio Shack.
Nov 13, 2009 | Philips 42PF9630A 42 in. Plasma Television
My Philips 42PF9630A/32 screen is black. The
X or Y sustain boards need servicing or replacement............
Nov 02, 2009 | Philips 42PF9630A 42 in. Plasma Television
I have philips plasma tv model #42PF9630A with ambient light
last time I had seen these syptoms on Philips plasma it was bad panel. Replace tv panel is too expensive to replace.
Aug 29, 2009 | Philips 42PF9630A 42 in. Plasma Television
I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Aug 26, 2009 | Philips 42PF9630A 42 in. Plasma Television
I have a philips 42pf7220a/37. when i turn it on the picture is fuzzy and red.
Any luck with fixing your Model#42PF9630A/37 as I am having the same problem with mine?
Feb 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9630A Not Working - Red Led Blinks 7 Times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 11, 2017 | Philips 50PFP5332D 50 in. Plasma...
Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Jun 27, 2008 | Philips 42PF9631D 42 in. Plasma Television
Black Screen after 5 mins. of use
Question when u loose picture do u loose sound also ? If so there is an 27Mhz xtal on the (SSB) small signal board that needs to be changed when it heats up it cycles out of phase. when it cools down it will work again till it heats up.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
