Anybody here??i have the error LE for my washing machine,but my manual book dont know keep to where.....is it anybody can help??
  • 15,935 Answers
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error, but it is possible to separate the working from the non-working, just by following a process.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 23, 2010
LG WASHER LE CODE
Fix for Error Code "LE" on LG Front Load Washing Machine
I just had an interesting experience with our LG washing machine today. I found some hints for the solution online buried in some user forums, but I thought posting my particular solution here in a less cluttered blog might make it easier to find.
I had just run a load of laundry, emptied the machine, and reloaded. I put the detergent in and started the machine. After sitting for about 2 minutes with no activity, a "LE" error message appeared.
While the online forums indicated this might be a problem with a sensor, I was able to solve the problem by doing the following:
1. Press the Power button
2. Manually rotate the hopper 4 times clockwise and 4 times counter-clockwise.
3. Press the power button and run the machine normally.
Don't know if this will work for everyone, but it worked for me. If I keep getting the error message, I'll have to call LG and find out about this sensor I was reading about.
May 30, 2014 | LG WM-2277HW Front Load Washer
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
Error message " LE "
Click the link below to troubleshoot the LE error on your daewoo washing machine:--- http://technoanswers.blogspot.com/2011/06/le-error-on-daewoo-washing-machine.html ----------- This should help.Thanks.Helpmech.
Jun 01, 2011 | Daewoo Washing Machines
What does the error code LE mean?
Might be a problem with a sensor, could to solve the problem by doing the following: 1. Press the Power button
If this dont work, the RPS sensor is on the rear of the washing machine, the error code LE is very common on these washing machines, the sensor needs to be replaced 99% of the time.
Depending on the selected program and which cycle is currently running, the PCB will tell the motor which speed to run at and which direction to turn. The Hall Effect sensor on the main circuit board is fed operational feedback from the motor. If there is any difference between what the motor should be doing and what it is actually doing - the appliance will stop operating and display an "LE" error.
Hope this helps.
May 05, 2011 | LG WM2487H Front Load Washer
My washing machine stopped spinning and displays LE on the digital pad.help me out
dont know what brand you have mostly LG. LE error is hall sensor is bad
Oct 24, 2010 | Washing Machines
Samsung washing machine smells
the LE error code is an over suds error.
the smell could be coming from lint and foreign object matter collected in the rubber bellows that is conected to the drain pump this should be cleaned out i hope this helps
Sep 07, 2009 | Samsung Washing Machines
E10 error message
I have had the same problem on an AEG. The problem it refers to is that there is not enough water entering the machine. Either the water pressure is too low or there is something blocking pipes/filters. Hope this helps
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Error code LE
Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
May 27, 2007 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
Top Washing Machines Experts
