Question about Troy Bilt 5.5hp Self Propelled Mower
I have a Troy-Bilt mower 5.5HP Model #:12A-264u011 While i was mowing it just died and when I pushed the primer it wasn't getting any fuel
  • Troy Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Aug 23, 2010
How to change blade on troy bilt 12a-264u011
Blade bolts are usually clockwise or right hand thread
Oct 19, 2014 | Garden
How to change blade on a troy-bilt mower model 12a-264u011
Turn mower on it's side with the carb facing up (otherwise fuel will pour out of the carb) There should be one bolt holding the blade on, remove it and the blade will come off. Install new blade in reverse order. Use an impact wrench if you have one otherwise use something to keep the blade from rotating when removing the bolt with a wrench.
Oct 19, 2014 | Troy Bilt 5.5hp Self Propelled Mower
My Briggs and Stratton powered (17.5hp Intek model 311777) Troy Bilt riding mower idled down slowly and died. It was a very hot day after about an hour of mowing. I don't appear to be getting an
Hi, armature is for spark and you stator is only for charging the battery. Check for spark again after disconnecting the single small wire from the armature incase its a safety switch issue, regards Phil.
Jun 06, 2012 | Garden
What kind of oil does my Troy-Bilt 12a-264u011 5.5 HP walk behind mower use?
You can check your manual but i would use SAE 30, if in doubt call your Troy Bilt dealer
Jul 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt front wheel drive mower, model
ya the trans is trying to go out and thay look up thay do that all the time
Nov 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Need a fuel tank for a Troy Bilt mower
You won't find the fuel tank on MTD's site because it is part of the engine. MTD makes the mower, Briggs and Stratton makes the engine. Get the model and type number off the engine and search Briggs and Stratton's site or post it here and I will tell you the part #. Dwain
May 21, 2009 | Troy Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
354 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
