Question about Whirlpool LSR5132PQ Top Load Washer
The wash basin is hitting against the side if the machine
  • 15,935 Answers
Check the inside for a broken suspension damper.
Typically you can tilt the machine back and look underneath.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 23, 2010
Testimonial: "Thank you for the identifying the problem!"
Leak
Try hitting it firmly with the flat of your palm a few times. If it is rusted in place that may shift it.
Oct 19, 2009 | Washing Machines
Washing machine stops in the middle of washing and then restarts. Machine fills and washes at the same time.
Could be that your discharge hose is causing the machine to syphon off water because there is no Air Break in the system
Test is to hook the hose into a basin and see if it does a full normal wash
Also could be problem with the pressure switch falsing due to a soap build up in the Air Bell on the side of the drum
Jul 08, 2009 | Kenmore Washing Machines
Basin no longer turns on Whirlpool washing machine.
Remove the back cover and see if the belt is still there.
Mar 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG Fuzzy Logic
The load is "off balance"
check the vibration dampers are solid and the springs at the bottom of the tub are intact.
Jan 07, 2009 | Washing Machines
Knocking while spinning
something is loose or broke you need to remove the bottom panel and top panel and see what is hitting may be a strut
Nov 29, 2008 | Whirlpool Washing Machines
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kemore Won't Agitate
ck lid switch raise lid and slowly close listen for slight click if none heard switch is not making depending on model some switches are on right side and has a small opening where lid strike hits it or could be underneath console area
Aug 06, 2008 | Kenmore 22422 Top Load Washer
Rusting basin
If you still have your book, look in the warranty section. The baskets on most models are covered 5 or 10 years against rust. That covers the part but not labor.($130-$160) If the rest of the machine is in good condition, it would probably be worth it. If you don't have your book, look up your specific model on the Whirlpool website and you should be able to find the warranty info. If it is no longer covered, the repair cost would probably not be worth it.
Oct 08, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSR5132PQ Top Load Washer Logo
206 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
