Question about Kenmore 15208 Mechanical Sewing Machine
My bobbin thread keeps breaking off - Kenmore 15208 Mechanical Sewing Machine
  • 35 Answers
Check that upper thread is correctly threaded and has proper tension.
Check bobbin tension.
Check that bobbin is installed correctly.
If those things don't work we'll go from there.
Posted on Aug 23, 2010
The thread keeps cutting off as I am sewing, what I'm I doing wrongly.?
have you lubricated your machine and bobbin case area? have you checked thread tension on both upper and bobbin thread? Too tight at the top can cause the thread to break. Poorly lubricated or improperly seated bobbin case can also break threads. Also if your needle can be moved left or right, and it's set off-center that can break threads. Good luck.
Oct 03, 2014 | Sewing Machines
What to do when the thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Jul 10, 2014 | Singer Sewing Machines
Thread keeps breaking
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
The bobbin thread keeps breaking
Jan 21, 2013 | Brother Sewing Machines
My thread keeps breaking and the bobbin tension is too loose
adjust the top thread tension one number or letter higher at a time
and sew on a scrap piece of fabric till the stitches look normal
The needle thread breaks
Jan 15, 2013 | Sewing Machines
Bobbin thread keeps breaking
if you don't have a manual, here is a link for a free manual
http://www.singerco.com/uploads/download/1295_3270.pdf
Dec 21, 2012 | Singer 3343 Mechanical Sewing Machine
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Sewing Machines
Thread keeps breaking, sounds like something keeps catching in the bobin area that causes the thread to break on top, skipping stiches also
You could possibly have some burs on the bobbin casing. This will cause threads to break. This is a repair that will have to be done by a professional. OR you could have place the bobbin in backwards. If the bobbin is not in correctly it will not have the right tension and the thread will break. And finally, make sure the upper threading is correct. The thread needs to go through all thread guides and the needle needs to be place in the machine with the grooved side facing you.
I hope this helps. If it does, please rate my suggestion!
Jun 01, 2011 | Kenmore 19606 Computerized Sewing Machine
Upper thread keeps breaking bobbin thread grtting cut on bobbin,
you need to change your needle first. then if that does not work you may have a small area on your bobbin case that has been damaged
May 22, 2009 | Baby Lock Esante
Kenmore 15208 Mechanical Sewing Machine Logo
44 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
