Need router or modem for ATT DSL 6.0
I am thinking about going with ATT DSL extreme 6.0 internet service. I have a toshiba L45 laptop. I do not know what type of router or modem I need.
  • 3,587 Answers
That usually comes from the ISP, no?
Posted on May 04, 2008
My 2 wire modem is acting has the ether net and the wireless constantly blinking, and the dsl and internet cannot seem to stay on green at all. I am having a troublesome time because I am trying to do my...
ATT is your high speed internet provider and they supply you with 2wire DSL modem which has alot of power supply adapter going bad (you can Google 2wire AC dapter problem).
You can buy your own DSL modem but the key is the setting it up, it depends on how your ATT DSL system is setup, DHCP, PPOe, etc. What ever you do I hope you do have the user name and password that you may need to setup the new modem.
To explain exactly how here will take many many words and pages to explain, and without knowing your exact setup, it will be real difficult.
ATT does not care if you use your own DSL modem but they will not help you setting it up.
I would suggest you to get someone at school that knows a lot about computer, may be aks your school IT person to see if he/she can help you for free pizza.
I hope my explanation will help you out.
Dec 10, 2010 | Computers & Internet
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Wireless system strength on laptop away from router
I don't beleive it's your dsl, It seems to be a problem with your router, since it sounds like it is not broadcasting well. Consider a new router before ridding of your ATT DSL.
Apr 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Recently I subscribed ATT DSL Service conflict IP Address
the motorola modem that att is using uses 192.168.1.x subnet. log onto your router and change it to 192.168.b.x where b is any number between 2 and 254 (just not 1). You should also log onto the modem and change the setting that allows it to share the external ip address with the router. You will need to do this if you plan on accessing your network from the internet.
Apr 25, 2009 | Motorola Computers & Internet
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
Feb 16, 2009 | Linksys Wireless-G WRT54GS Router...
How to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also
Jan 05, 2009 | NetGear WGR614 Router
Your laptop has got a modem built in, but it is intended for dial up 56Kbps, not DSL. So they are both right. But if you want to use a DSL internet service you will need to buy either a DSL router or modem. You should not need to buy bothas the router will have the modem built in. Your ISP may have a prefered model and will probably sell you one at a fairly cheap price or you can get one from your local PC world. If you only have the one Laptop at home you can buy either the router or the modem. The modem will probably be cheaper. But for around $60 you can buy a router I prefer wireless. This will allow you around 4 connections and more importantly frees you up from having to be directly and closely connected and allows you to work in various places around the home without trailing cables everywhere. Your ISP will advise you on the settings you require. I advise you to enable all the security options on any wireless devices. I hope this was useful.
Jul 21, 2008 | Computers & Internet
Help please
you can go to any wi-fi locations near your area and access the internet on your laptop. I think AT&T offers wi-fi access to its members on any of its designated hotspot /wifi locations (nearly 15,000 company-owned & roaming) e.g. McDonald's, Barnes & Noble bookstores, leading airports, coffee shops, etc. you can visit and login to your account to find more details.
or call them at: 1-888-888-7520
you don't need to install any software/ dsl installation on your laptop when you are using a public wi-fi connection, just ensure that your computer firewall is on and take precautions when sending out any personal info online.
Apr 30, 2008 | AT&T High Speed DSL Modem
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
