Question about Microwave Ovens
Our Colony House range hood is quite old, the exhaust fan motor has bearing that are on the verge of going out. I need to find a supplier for these parts, my other problem is that the unit has no serial # or model #. I would like to know if these parts are still available before I take the motor out
fridgetech
  • 473 Answers
SOURCE: Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Posted on Oct 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave vent fan replacement.
The part # SMV-260UA runs just under $60 from SamsungParts, depending on which of three versions you choose. You can find them here.
And a simple Google search shows quite a few hits for "SMV-260UA" and they seem to run about $40, assuming the listings aren't bogus - as so many search results are.
I have a few "new old stock" and used vent & cooling fans here.
I would be happy to supply one whole or just the blades if you like.
Just tell me the dimensions: diameter of the shaft hole and the length and diameter of the "squirrel cage" itself and I'll see if one of mine would work.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
rickzilla
  • 706 Answers
SOURCE: Microwave range hood install -- stud in middle of exhaust
You have a few options, First off, I am assuming that the stud you refer to is an outside wall. Assuming that is true, then you have a few options.... one of them is to cut thru the stud and run the vent out. Even if that stud is on a bearing wall ( meaning it is carrying a roof load above it) ... It is unlikely to pose a problem if that one stud has been compromised with it cut out, If that concerns you.. and you are handy, you can open that area of wall up from the inside and box the area that the vent will be located in with short pieces of 2x4 to the studs on either side of it... Another option is to vent the hood up thru the cabinet above and direct that out slightly offset to the stud in the wall..
One thing I have done is to cut the stud out and then to place a piece of 1/2" plywood in the area that the micro/hood will be located and attach that piece with drywall screws to the studs in the wall.. That piece of plywood will help support the stud you cut when you screw it to the adjacent studs and also act as a place to secure the hood mounting bracket on the wall. Granted, it shifts the hood out from the wall 1/2 " but then you have plenty of surface to secure the plate and don't have to worry about hitting a stud or using wall anchors.. I hope you understand my comments..If not...please respond to this and I will provide additional information to clarify this... Hope this helps !
Posted on Aug 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: mco153ub microwave
You can order the door handle here, but it may be on backorder.
You'll have to check back or contact them directly about backordering it for you.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Exhaust fan does not run
Yes, It sounds like the control board needs to be repaired.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week in most cases.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 17, 2008
My hood fan quit working on my kenmore microwave/ hood combo. How do I fix?
Check to see if fan is getting power. If it is and the fan does not turn then you need to replace that motor. Also check motor bearings - not uncommon for them to get all gunked up with yuck from the air they push through the hood.
Aug 23, 2017 | Kenmore Microwave Ovens
Spontaneously stops working and then comes on after 5 minutes. Why?
Sounds like the magnetron is overheating. There is an automatically-resetable thermal circuit breaker attached to the magnetron. Most likely your problem is caused by either a cooling fan that is not running, or is running too slow (caused by gummed-up bearings). In some over-the-range (OTR) microwave ovens, the exhaust fan is run at a slow speed to cool the magnetron, and if it's bearings get gummed up, it won't run on the slow speed. But if it's a new OTR microwave, then the exhaust fan may be pointing the wrong way. (It is rotatable, depending on the installation). For example, if it is pointing up, but you don't have an exhaust vent over the microwave, then the air has nowhere to go, and the magnetron will overheat.
Oct 16, 2014 | Microwave Ovens
GE Spacemaker JVM1640SJ Exhaust Fan Whines & Doesn't Do a Good Job
The vent fan assembly's blade assembly may be freewheeling on the motor shaft (which can be fixed with a couple of drops of super glue or epoxy) or there may be a foreign object or critter in the fan blades.
You will have to remove the oven from the wall to inspect and remove and inspect the vent motor. You can download the installation instructions here.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order any needed GE parts from the Pros here, my favorite affiliated supplier.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Exhaust Fan makes noise
Check to make sure that nothing is obstructing the fan blade causing the noise, if not then the bearings in the fan motor are more than likely going out causing the metal on metal noise.
Apr 24, 2012 | GE Microwave Ovens
We have a Kenmore builin icrowave with exhaust hood over the range. The exhaust fan appears to recirculate the air into the kitchen and not sending it out. This causes the cooking smell to remain inside...
some fans have a charcoal filter that needs replacing others are supposed to be vented out side by the roof or out the wall to see if the vent is going outside you will have to unmount the unit tak it down and check and see if it is conected to a duct in the celing or through the wall hope this helps
Mar 09, 2011 | Kenmore Microwave Ovens
Fan just circulates air instead of exhausting the air outside
The exhaust motor was not installed properly - it has to be turned 90 degrees so that the blower openings face up instead of the front. Whoever installed it didn't read the directions:)
Unfortunately, the unit will have to be taken down from the wall to correct the motor.
Dec 21, 2008 | Maytag MMV5207AAS Microwave Oven
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Aug 13, 2008 | Hotpoint RVM1635 Microwave Oven
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Exhaust fan
It sounds like the bearings may be going bad on the fan motor. It's also possible that there may be sonething stuck in the the grlle or fan area, like a paper label, etc. You can find exploded views and order parts here: http://tinyurl.com/gv383 We have critical safety and disassembly help files at our site, which you can find via our listing here: http://tinyurl.com/yzjozk
Jan 23, 2007 | Whirlpool GH7145XF Microwave Oven
Microwave Ovens Logo
995 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
