Question about HP DeskJet 6988 Printer
Cleared paper jams 3 times in succcession.....still have problem What can be the problem
  • 1,218 Answers
Get help.... http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
or
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert technician to mend it.
Posted on Sep 15, 2010
Hp officejet j4580 allinone error clean paper jam solution
Posted on Aug 24, 2010
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Paper jammed when loading paper, don't know how to clear jam
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 24, 2011 | HP Photosmart 2610xi All-In-One InkJet...
Cannot clear paper jam
Paper Jams in the Automatic Document Feeder
If you're loading legal-size paper, insert only 10 sheets at a time to prevent paper feeding problems.
If paper jams inside the ADF, clear the jam and reload the paper as follows:
1.
Open the ADF cover and remove any jammed paper.
Caution:
Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism.
2.
Press OK, then select Yes and press OK to clear any messages on the display screen.
3.
Reload the paper. Make sure the corners of the paper are not bent, folded, or curled up.
Jan 11, 2011 | Epson WorkForce 600 All-In-One InkJet...
My printer has a paper jam but there is no paper jammed in my printer what do i do?
run the roller cleaning application in maintenance a few times then turn your printer upside down and gently shake it side to side to clear any foreign objects that may have fallen down the paper feed.
I know it sounds silly but on 3 occasions now i have cleared the "jam".
Nov 30, 2010 | HP Office Equipment & Supplies
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Paper jam
if you cleared the paper jam an your printer still shows this paper jam, you may try this:
1. after you clear the paper jam, turn off an on the printer.
2. if above advice is not working you may try to look more carefully (with a flashlight maybe) if a small piece of paper is not blocking the paper jam sensor.
3. unfortunately this is a job for a qualify serviceman.
4. in less then 2-3 % of cases is a defective sensor, and must be replace by a serviceman.
Sep 23, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
HP 3419A
Hi Mose,
I never faced this problem any time , but could find a solution for you which i think will be helpful.
The paper jam error state occurs if the printer detects a paper at the platen after attempting to eject paper to the out tray. Clear the paper path.
<Power and Resume>
1. Turn the printer OFF and back ON to allow the printer to clear the jam.
(If the paper remains jammed, turn it back OFF and follow the remaining steps.)
2. Open the top cover and remove the OUT tray.
3. Pull the jammed paper out of the printer by grasping the middle section of the paper.
4. Remove all torn pieces from the paper path.
5. Remove any wrinkled or torn paper from the IN tray.
6. Reload the paper stack.
7. Replace the OUT tray and close the top cover.
8. Turn the printer ON.
Hope this answers your problem, Please let me know by providing your valuable feed back
Thanks,
Robosoft.
Dec 24, 2007 | HP Photosmart 375 InkJet Printer
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
HP DeskJet 6988 Printer Logo
220 people viewed this question
Seeker5211
Seeker5211
