Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
Clean light flashes 7 times and will not run wash cycle I have replaced heat element
  • 128 Answers
Big guy this happened to me the other day do this it will reset computer you ready hit these buttons heated dry normal heated dry its a code all lites will then come on that resets computer
Posted on Aug 23, 2010
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
Dishwasher won't run
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 09, 2010 | Kenmore 17024 Built-in Dishwasher
Dishwasher is locked out. Clean light flashes 7
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Jun 06, 2010 | Kenmore 17024 Built-in Dishwasher
Mod #gu2500xtpb1 clean light flashes 7 times
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats--
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence--
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes). You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Clean light blinking will not start
If the clean light flashes 7 times, pauses, then repeats...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
Apr 06, 2009 | Whirlpool 24 in. GU2500XTPS Stainless...
Clean light flashes cant get to start a wash cycle
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It's not as common but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 07, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
My clean light is flashing....call service to check heater?
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Mar 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Clean light will not go out
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 04, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Clean light blinking, will not run at all
-high temp wash
-heated dry
-high temp wash
-heated dry
Jan 13, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Clean light flashes constanly. Won't clear out to start new cycle
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
115 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
