Question about Bushnell H2O 13-2412 (12x42) Binocular
I own the Bushnell binoculars 21-1242 waterproof. The focus knob is broken. Can it be fixed? Can not focus them.
Easy they are under warranty for 30 years from date of purchase send therm back to bushnell...
Posted on Jul 20, 2013
  • 73 Answers
SOURCE: unable to focus my Bushnell 7x35 insta-vision binoculars
If it just turns without making the bridge between the two eyepieces move up and down then they are broken. You will need to send them to Bushnell.
Posted on Jul 31, 2009
  • 112 Answers
SOURCE: Bushnell 10 - 30X50 adjustment
on some models the center focus control is located on the center hinge,it should be flat,and not hard to find,if there is no center wheel this is where it should be...good luck...larry@reichinstruments.com
Posted on Nov 27, 2008
  • 112 Answers
SOURCE: bushnell binoculars /double image
they have to be aligned if you want mail them to me for an estimate..larry@reichinstruments.com
Posted on Apr 22, 2009
o0zappa0o
  • 7 Answers
SOURCE: The adjustment knob was very hard to turn. Any way to lubricate?
I would be inclined to use a penatrative aerosol lubricant (like WD-40) in very sparse quantities. Squirt a little in using the WD40 smart straw applicator to direct the lube accurately and work the adjuster back and forth in a small section. Repeat this until you have freed up the adjustment from one end of its scope to the other. The focal adjustment is typically housed separately to the lenses and careful application of the lube should not affect them - avoid overusing the lube and have a mopup cloth under the spray zone to keep overspray/drips to an absolute minimum.
Posted on Aug 18, 2009
  • 906 Answers
SOURCE: bushnell binoculars model 111025
Link
Please try above link to contact Support team of Bushnell to address your query for a software for your binoculars.
Thank you.
Posted on Jul 29, 2010
The locking diopter ring on my Bushnell 8x42 Legend Rainguard HD binoculars doesn't have enough (-0)range to bring subject into focus.
Are you focusing on near or distant objects ? If near, it may not have sufficient close focus travel.
Oct 16, 2016 | Bushnell Optics
Lens cap for Bushnell 10 x 42 waterproof binoculars
Contact a local retailer and have him order it.
Sep 21, 2016 | Bushnell Optics
The diopter setting eyepiece has come out of the body of my Bushnell 10X42 ''Waterproof'' binoculars, model 13-2410. I see keyways inside, but cannot screw it back in more than about 1/4 turn, which is...
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Apr 10, 2010 | Bushnell Waterproof Binoculars
There is some sand or dirt under the focus knob that makes a noise when the knob is turned. How do you take the knob off to clean . Thanks
There is a central aluminium decal on the focus knob. CAREFULLY prise it off using the tip of a sharp knife trying not to distort it (it's hard to panel beat a small bit aluminium!). Once off you should see a central screw or two screws that hold the focus wheel in place. Remove the screw(s) and the focus wheel noting the orientation of the focus wheel to the body. Use a dot of Liquid Paper to show registration. You can then clean around the focuser and the inside of the focus wheel before reassembly.
Jan 03, 2010 | Swift 10x42 HCF Viceroy Waterproof...
Bausch and Lomb rubber eye cups
Bausch & Lomb was purchased by Bushnell in the 70's. Your elites are Japanese made and considered quite a good binocular. Bushnell continued to make the same binoculars bearing the Elite name but replaced B&L with Bushnell. The current elites are different shaped. You could contact Bushnell or you could go to a store in your area that may stock the older Bushnell Elites and try and see if the eyecups fit.
Jun 13, 2009 | Bausch and Lomb Elite Waterproof (8x50)...
Unable to focus my Bushnell 7x35 insta-vision binoculars
insta-vision bino's are self focusing no adjustments.
Jun 05, 2009 | Bushnell "Insta-Focus" Binoculars
Bushnell night vision binoculars
They do stay on for a while after switch, that is OK. Dim and out of focus may indicate that the output voltage is low. If replacing the battery does not fix it, then the problem may be in the power supply circuit.
Nov 08, 2008 | Bushnell 26-0400 Binocular
Bushnell H2O 13-2412 (12x42) Binocular Logo
934 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
