Question about Nikon COOLPIX S610 Digital Camera
My Nikon S610 reads !Lens Error - Nikon COOLPIX S610 Digital Camera
    Sergeant:
  • 420 Answers
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
t00nz
  • 4738 Answers
SOURCE: how can i fix a lens error on s610?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jul 14, 2009
leethedeuce
  • 4472 Answers
SOURCE: i have the nikon coolpix s610 digital camera that
Ok, being that it is 6 months old highly advise you just have it serviced under warranty.
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Follow this link for all the information having to do with starting the repair process.
Thank you,
Lee
Posted on Aug 08, 2009
  • 115 Answers
SOURCE: how much would it cost to replace a lens on a
you could get it on ebay any camera store in your are ,but my suggestin to you it will cost more then the camera ,parts and labor.if my info was of any help to you please leave a comment ,thankyou.
Posted on Sep 02, 2009
Testimonial: "thank you . I was actually going to bid on a broken one on ebay and fix it if I won it. But I wont waste my time with it then. Thank you!"
SOURCE: need to open and repair nikon s610
before you would disassmble here are a few things which u need to try if ur lens is stuck....
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Sep 29, 2009
  • 102366 Answers
SOURCE: my coolpix camera reads lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
Why won't lens retract into camera?
I had that on a Canon. You need to send it take it to a Service Centre. There is nothing you can do apart from make sure the battery is good.
Apr 01, 2016 | Nikon COOLPIX S610 Digital Camera
Lens error
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Nikon service as you do not have to run around for the damaged spares.
Jan 06, 2011 | Nikon COOLPIX S610 Digital Camera
When I try to zoom in it says "lens error"
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 16, 2010 | Nikon COOLPIX S610 Digital Camera
How much would it cost to replace a lens on a nikon s610? where do you buy the part to replace it?
Sep 02, 2009 | Nikon COOLPIX S610 Digital Camera
How can i fix a lens error on s610?
Jul 13, 2009 | Nikon COOLPIX S610 Digital Camera
Blank screen in Nikon S610 camera
CCD FAILURE !
kindly call Nikon for FREE REPAIRS
Pls rate me WELL !
Jul 07, 2009 | Nikon COOLPIX S610 Digital Camera
My coolpix camera reads lens error
Jun 25, 2009 | Nikon Coolpix 2000 Digital Camera
Nikon COOLPIX S610 Digital Camera Logo
106 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
