Question about Epson Stylus C86 InkJet Printer
Mac OS 10.6.4, new driver Gutenprint 5.2.3 and new set of ink cartridges. Printer goes through motions to print, paper is blank - a test page had a very faint blue image but nothing else. I can't get the head cleaner, either.
  • thomashub719 Aug 26, 2010
    New driver doesn't work - symptoms as per original description persist.
  • 10,319 Answers
Download a new driver which maybe updated ( they are free)
It may print as new again
I have tried this on a few with the same symptoms and it did do the job to correct this problem
Posted on Aug 23, 2010
Lexmark 730 not printing
Regarding the Lex1 cartridge's no printing/severe fade (or similar) during printing, my answers are provided below:
For the poor print quality problem (degraded image quality) you are observing, we suggest you first visit the "Print Quality" page of the "General Information" section of the Inkjet 411 website and follow the suggestions provided: http://inkjet411.com/?page_id=1432
A. 1. Cartridge & Printer maintenance should also be evaluated - ensure both ink cartridges and flexible driver contact cables (where the cartridge interfaces to the carriage inside the printer) are thoroughly clean: http://inkjet411.com/?page_id=1519
A.2. Perform a hot-water flush on the suspect ink cartridge, refer to video procedure here: http://inkjet411.com/?page_id=1519
A.3. Run a quick test print to evaluate cartridge performance (i.e. 4-color test print):
http://inkjet411.com/?page_id=146
For information on North American ink refill services (for Lexmark 1, 2 and 3 ink cartridges) at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced Lexmark printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jul 16, 2013 | Lexmark Office Equipment & Supplies
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
My dell printer goes through the motions of printing but keeps coming up with a blank page. I have reinstalled the printer, unplugged it to reset any codes, cleaned the cartridges with warm paper towel,...
Hi
Please try to add or set up the printer again and set it as default printer. and then try to print the test page.
If not, remove the cartridge and rub the print head into a plain paper with alcohol until inks flows on the paper. Return the cartridges and run the print nozzle for 2-3 times. Then try to print again.
Please let me know if you need more help. Please rate my solution if it helps you or might help others.
Mar 01, 2011 | Computers & Internet
My hpf44880 printer prints out blank sheets of paper what do I need to do to get it to print with ink on the paper?
please follow these steps:
1.please print a test page from printer(hold down power and cancel(red X)buttons for 3 seconds together and release both of them..it will print a test page
2.if it is blank :please take out the cartridges.
clean the metallic contacts with lint free cloth
clean the ink cartridge slots with a cutip
disconnect usb cable
unplug the power cable from the back keeping cartridges out
hold down power key for 30 seconds
reconnect power cable
reinstall the cartridges
3.print a test page again from printer if printer is quiet
4.if the test page is still blank..u need another set of cartridges
5.if test page isn't blank and u print blank pages from computer,do the following:
6.if printer s/w is already installed..please go to devices and printers(printers and faxes in win xp)
7.please click on add a printer
8.select driver manufacturer as HP,and driver as deskjet 990c(this is the generic driver for all HP printers)
9.follow the onscreen instructions,and finish installation
10.try printing with this driver
Jan 24, 2011 | HP F4480 All-In-One Printer
Mac OS 10.5.8 HP Photosmart C3180 does not print
Exactly what I'm experiencing, it goes though all the motions, but no ink is on the paper. I just installed 10.5.8 last night on my Mac Pro. The drivers are up to date, but no ink hits the paper.
Sep 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
No black ink is appearing on paper
If this is an old printer. The nozzles might be clogged. A Q-tip with a little alcohol might get some of that dried ink out. Be careful it could get messy. Also see if your printer has a built in cleaning test. you might have to access the test from the printer tools on your computer.
Jul 30, 2009 | HP Officejet 5510 All-In-One Thermal...
Only test pages print perfectly!!
If when you print a test page it comes out perfectly, that means that the printer works, and the problem is communication between the printer and Mac.
Try the following:
Start testing a different USB cable and a different port.
Unplug Mac, and eventually remove the battery.
Unplug the printer power cable and USB.
Put the mac back toghether and restart it with printer usb not connected.
When mac is on, reinstall printer software driver, with Mac still not connected to printer, using printer disk or download.
Connect printer to Mac when asked by software.
If that still does not work, test the printer on a different computer, even if it is not common, the printer may have a faulty USB port.
Feb 28, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark z640 has stopped printing - goes through the motions but no ink on page
Some third party cartridges will not work with your printer as they are remanufactured from used cartridges.
It is more expensive to buy genuine Lexmark ink, but atleast you know it will work.
You may try reinstalling the driver before buying new ink.
I hope this helps.
Good Luck.
Oct 18, 2008 | Lexmark Z640 InkJet Printer
Printer HELL !! need assistance
illustrate on how to replace the ink cartridge on printer
Sep 15, 2007 | Office Equipment & Supplies
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
