Question about PNY 2GB microSD Memory Card
I have a 2gb micro sd card and I won't allow me to put music on it it tell me that it's write protected
  • 32,281 Answers
Most SD memory cards have a little slide switch on the side of the card. This slide switch is a write protect switch, slide the switch to the read/write position.
Posted on Aug 23, 2010
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card is locked how to unlock
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
I am trying to sync music to my memory card but windows media keeps telling me that my memory card was write protected. How do I fix this?
If ou're using a Micro SD Adapter then there's a little tab on the side that when slid down write protects the Card thats inserted.
Jul 09, 2011 | SanDisk 2GB microSD Memory Card
I've Been Syncing Music Onto My Micro SD Flash Reader With No Problem Until Now. It Keep Saying Can't Create or Copy Certain Files Because The Disk Is Write-Protected and Would Like To Know How To Remove...
On the SD Card adapter housing for a Micro SD card, look along the edges and you will find a small tab. This tab slides back and forth to either lock or unlock the card. It is for write protecting you files.
Feb 25, 2011 | Kingston MicroSD 2GB (2 Gigabyte) Card for...
Cannot format sd card
You are probably trying to format a micro-SD card that is greater than 2GB eg, micro-SDHC (High Capacity) of 4GB or bigger are not supported by 'older' devices. Stick to 1Gb or 2Gb standard microSD cards for your device.
Hope it helps. Let me know how you go.
Jan 13, 2010 | Samsung SCH-u740 Cellular Phone
Won't store max amount of memory
I tried copying music to my PNY 2GB, too, and it stopped accepting after about 720 MB. I deleted all the music I had on it, created half a dozen new folders, renamed them, then put as much music as I wanted on the SD. I haven't tested it on my phone yet but at least it let me copy all the music I wanted.
Apr 14, 2009 | PNY 2GB microSD Memory Card
Cant instal micro sd card to samsung E250
Hey! samsung SGH-E250 doesn't support 4GB memory card. Try a 2GB or 1GB memory card.
Jan 04, 2009 | O2 Samsung SGH-E250 Cellular Phone
Samsung micro sd memory card
THE CARD IS WRITE PROTECTED
OR THE FILES COPIED ARE WRITE PROTECTED.
SO REMOVE THE WRITE PROTECTION ITS LIKE A SMALL SWITCH WHICH SLIDES ON THE CARD .. ONLY CERTAIN CARDS HAVE IT .
NOW IF THIS DOESNT WORK
PUT THE CARD IN A PHONE AND SEE PROPERTIES OF THE DATA THERE , REMOVE WRITE PROTECTION .
Jun 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PNY 2GB microSD Memory Card Logo
129 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
