Question about GE Energy Star WCVH6260F Front Load Washer
How to replace door gasket for GE WCVH6800J0mr
    President:
  • 1,554 Answers
The front panel needs to be removed in order to replace the door gasket. This requires the removal of the top panel, control panel, service panel. Disconnect power to the machine before attempting any repair works.
Remove the 3 Phillips-head screws that attach the top cover then pull the cover rearward. It may be helpful to place a putty knife along the top seam between the cover and control panel then lightly tap it rearward. Remove the 3 hex-head screws that attach the rear of the top panel to the cabinet then slide the top panel rearward and lift the panel.
Remove the 3 Phillips-head screws that hold the service panel to the cabinet then pull the service panel down and off the cabinet.
Pull the dispenser out to the stop position then How to replace door gasket for GE WCVH6800J0mr - 348c947.jpgon the locking tab.
Pull the dispenser out completely thenHow to replace door gasket for GE WCVH6800J0mr - bfa0d44.jpg single Phillips-head screw from the control panel dispenser recess.
Remove the 4 Phillips-head screws that attach the top of the control panel to the control panel cover.
Lift and push forward on the control panel from inside the cabinet to release the bottom tab How to replace door gasket for GE WCVH6800J0mr - 307604b.jpgont bracket.
Lift the top edge of the panel to disengage the 3 tabs that hold the top of the panel in place.
Push the control panel towards the left then release the side tab. Disconnect the wire harnesses from the control panel then set the panel asiHow to replace door gasket for GE WCVH6800J0mr - 303bebd.jpgecommended to take note of the connections before disconnecting to prevent messing them up upon reconnection.
Open the door then remove the 3 Phillips-head screws that hold the door lock toHow to replace door gasket for GE WCVH6800J0mr - b26d9b9.jpgpanel and remove the spring and wire from the gasket.
Use a pair of long-nose pliers to grasp the wire hoop at the spring location and expand it to clear the door gasket and remove the spring and wire How to replace door gasket for GE WCVH6800J0mr - 8fd6b8c.jpgb26d9b9.jpg
Peel the door gasket off tHow to replace door gasket for GE WCVH6800J0mr - 72535b8.jpgp of the front panel door opening then position it behind the front panel. Close the door and remove the 4 Phillips-head screws that attach the front panel to the cabinet. Lift up then remoHow to replace door gasket for GE WCVH6800J0mr - 6e60d8e.jpgt panel from the hooks.
Once the front panel is off, pull down and disengage the gasket from the nozzle.
EHow to replace door gasket for GE WCVH6800J0mr - a9198ac.jpgthe washer is placed on the outside How to replace door gasket for GE WCVH6800J0mr - 7b202ed.jpge nozzle is aligned with the indent on the inside of the gasket when reinstalling.
Disengage the gasket from the wHow to replace door gasket for GE WCVH6800J0mr - 4d480d6.jpgpipe and loosen the 7-mm bolt that holds the wire and bolt assembly to the outer tub lip. Remove the wire and bolt assembly from the gasket then pull the gasket off the outer tub lip.
How to replace door gasket for GE WCVH6800J0mr - a65237c.jpgttp://i.fixya.net/uploads/images/f23184d.jpg" alt="f23184d.jpg" class="h_mi" />
Install the tub gasket on the outer tub aligning the notch in the gasket with the arrow located on the top of the outer tub lip before tightening the wire and bolt assembly.
When reinstalling the wire and bolt, tighten it to a gap of approximately 11/4 inches. Do not over-tighten it to avoid tearing up the gasket.
Position the door gasket inside the drum then secure the front panel back into the cabinet. Put the door gasket over the outer lip of the front panel door opening then secure it with the spring and wire hoop assembly. Start at the top then work around the gasket on both sides simultaneously until the gasket is completely secured.
Reinstall the service panel, control panel, and the top panel to complete the procedure.
Posted on Aug 23, 2010
  • kjbseven Dec 14, 2010
    Thanks! This was a great help. Couldn't have been any more concise and well pictured.
Ge pfs22mi door gasket
This is going to be tricky so watch the video and tell me if the answer to you question comes out and resolved by the tricks revealed in the below video.. Sea Breeze
When you say latch can you tell me the part number of the latch you say that you need replaced? Here is a link to the parts you are describing HERE
GE Profile French door bottom freezer Model # PFS22MISBWW Door Gasket and related parts
Apr 01, 2013 | GE Profile Bottom-Freezer Refrigerator...
Replace door gasket on GE wbvh5200j2ww
First of all, obtain a replacement gasket, then disassemble the door sufficiently to allow installation of the new gasket
Mar 23, 2013 | GE Washing Machines
GE GSS25WGMC freezer ices up at top. Fan motor makes loud noise as it ices up between defrost cycles. Door gasket (screw in type) was replaced and problem a little better but not cured. I'm told...
Try replacing your defrost timer it may not be working proper also if it has the coiled heaters behind the insulation make sure they are coming on as well they do burn out.Check heaters voltage and continuity first then defrost timer. If no heated defrost its defrost timer
Apr 05, 2012 | GE Refrigerators
Front door leaks
The door gasket is bad this page will help http://www.appliance-repair-it.com/GE-front-loader-washer.html
I know the page says GE front loader but replacing the door gasket is the same.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
Leaking at the bottom of a GE dishwasher
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Jul 11, 2009 | GE Dishwashers
Ldf8812st lg dishwasher leaking from front door
Thank you for the update. The retrofit kit will probably not only fix your leak but also dry your dishes much better.
I hope the info I provided was useful. Can you take a moment to rate my level of helpfulness?
Mar 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Replacing the door gasket on ge front load washer
very hard to replace if you hav not done it befor to get it installed correctly
Apr 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
1,115 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
