Question about Hoover Washing Machines
Gearbox is us on hoover RLA 800, have removed most stuff , motor etc,I am now down to the g/ box, how do I remove cheers alan.
    Brigadier General:
  • 3,513 Answers
Hi
Please go through the link bellow and read the discussion thoroughly to have a detailed idea regarding your query…
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?15992
Let us know if you want something more else please accept the suggestion.
Thanks for contacting fixya.com
Posted on Aug 23, 2010
Hoover 800 rla. Agitator spinning rapidly in one direction and tangling up everything. Been great for 10 years now gone mental. Please advise
In most washers, the reversing mechanism in the transmission broke. You probably will have to replace it.
Sep 04, 2016 | Hoover Washing Machines
Beater brush on hoover windtunnel dual v not turning
....As Ray Sabourin said, the front beater bar drive is a problem area. On my Windtunnel Dual V, the front gear overheated and upon cooling, the melted plastic on the gear fused to the gearbox housing! It was a pain to remove the gearbox, but once it was removed, I managed to separate the fused gear, turn down the damage on the gear in a lathe and machined out the damage on the case with a vertical mill. I then lubed everything with machine oil and put it all back together. It fixed it and saved about $75.00 because the gearbox is not available without also buying the electric motor that drives it. -A Difficult fix that could not be done without high mechanical skills. :-)
Mar 16, 2012 | Vacuums
Whats involved in replacing clutch how long to do
Please give all details Year, Make, Eng. size, etc. ....and then I would be able to help you better.
Thanks,
over4dy
Sep 19, 2011 | Mini Cooper Cars & Trucks
Motor replacement instructions
1. Remove the center caps from the rear wheels
2. use a 13mm wrench and loosen the bolts
3. remove the rear wheel
4. pull the motor and gearbox out and disconnect wires to the motor
5. remove the two screws that hold the motor to the gearbox
Nov 13, 2010 | Polaris 800 Twin Sportsman Ride on Toy
Replacing gears
you have to disassemble the tool completely. Remove chuck, remove battery, remove all screws holding body parts together, remove one side of body. Now you can see motor and gear box. Pull out both of them and twist gearbox a bit (just few degrees or millimeters) if it goes, then just pull gear away from the motor. Be carefull, some gear parts may drop of, so hold gearbox down and motor up. Juraj
Jun 04, 2010 | Makita 18V 1/2"CRDLS Drill Kit
Install peg perego gearboxes
remove the center cap from the wheels then you'll need 2 13mm wrenches one for each wheel to loosend the bolts at the same time, then remove the dump box by removing the two black push pins at the rear of the bed, and the red push pin at the base of the dump handle, then lift up the green plastic and this will giove you acces to the motors and gearboxes, then pull the wheels off and the axle out then with a philips screwdriver there is two phillips screws holding each gearbox to the frame, remove those then remove the two wire attached to the motor then you can take the gearbox and motor out then remove the two screws that hold the motor to the gear box, then do all of that in opposite order to put it back together
May 19, 2010 | Peg Perego John Deere Gator HPX
Type of lubricant required for a hoover model 800 RLA gearbox
Lithium grease.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 04, 2010 | Washing Machines
How to remove the gearbox from a 1999 suzuki swift car
disconnect battery remove it & its cradle
jack it up & drain gearbox oil
remove the wheel & undo the axle nut in the centre!
[do not remove it yet]
undo the bottom control arm at its pivot point under the axle then seperate them !
pull swiftly outward to remove the drive shaft from the gearbox!
now there is the gear selector & speedo & clutchcables & starter motor to diconnect & or remove
remove gearbox mount But support the motor from underneath
undo all the bolts around the gearboxes bellhousing!
use a pry or large flat bladed screwdriver to part the gearbox from the engine & lift gearbox up & out! its very tight squeeze in there!!
Im sure now that you regret asking lol
dont forget while its out you may aswell do the clutch
good luck!
Cheers Rob.
Jul 20, 2009 | Suzuki Swift Cars & Trucks
Hoover 800 RLA washing machine spins slow or not at all.
It sounds like the electric motor is dying!
Either pay a serviceman to come in to confirm this or buy a new machine.
New motors can cost anywhere from $380AUD to $600AUD.
Jun 17, 2009 | Washing Machines
Gearbox
what kind of car like certain mazda you have to remove speedometer cable or sensor add gear oil untill you see oil at the bottom of the hole some gear box take heavy gear oil some motor oil 5w30 dont put to heavy oil it gonna be hard shifting when cold cheers let me know what kind of car cheers
Jan 20, 2008 | Visonik V308XT 180W x 2 Car Amp Car Audio...
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
