Question about Roper Kitchen Ranges
We blew a fuse on the stove and replaced them but it still won't turn on, is there a reset somewhere on the stove. the only number we can find on the stove is 4454084 B
2 Suggested Answers
machinetech7
  • 1344 Answers
SOURCE: Electric stove fuse keeps blowing
more than likely the terminal block where the element actually plugs in has been shorted or damaged and every time you start that particular element it trips the breaker. This is a real easy fix, just take your time and you'll be just fine
Posted on Jun 20, 2012
My stove top and wall oven are connected to one
Assuming you replaced the fuse with the same size, yes, both are reasonably safe.
Oct 08, 2014 | Kitchen Ranges
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
Jun 19, 2012 | Kenmore Kitchen Ranges
Are there fuses in the whirlpool flat top accubake stove that control the oven?
Yes there is a thermal fuse for the oven that if it blew all power to the oven would be cutoff,the fuse is not resettable and if it blew would need to be replaced
Aug 05, 2011 | Ovens
Stove shut off and blew breaker. Once reset everything works but bottom heating coil. Had it checked, it works. No burnt wires in the back.
Check the oven switch. The bottom element is the main element while the top one is usually the grill element. If the breaker tripped there must have been an overload somewhere and you are possibly missing a connection or fused wire somewhere else.
Jan 22, 2011 | Kenmore Kitchen Ranges
1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Jul 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
99 powerstroke blew fuse for glow plugs
you've got a short somewhere, or one of the glow plugs is bad.
Dec 02, 2008 | 1999 Ford F250 Regular Cab
Kitchen Ranges Logo
46 people viewed this question
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Thurston
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
