Question about Kid Riffic Toys Toys
Kid-Riffic Toys LTD item #3818 walkie talkie spy watches ... put new batteries in but still do now work are we missing the microphone ear piece?
My little tikes red walkie talkies aren't working. One has static, the other is silent. What to I do?
check the batteries. When left on, the batteries will continue to dis- charge (and what kid turns things off?) and eventually ruin the battery.
Jul 10, 2015 | Walkie Talkies Radio Communications
Need accelerator switch for Wave Cruiser
Check with Kid Rific Toys for availability.
Jul 02, 2014 | Kid Riffic Toys Kidriffic Jump Smart
Manual
where do I find the user manual for my spy gear long range walkie talkies model number 70437.
May 10, 2013 | Wild Planet Spy Gear Long Range Walkie...
Spy gear walkie talkie
Spy Gear walkie talkie????
You've not given me any other info, so how can I help you?
Please reply with the following info:
1. Make & Model of your radio.
2. Your question in regard to the radio, i.e,. THE PROBLEM WITH IT.
Unless I receive as much info regarding your radio, I am unable to give you an answer.
Cheers,
Peter
Mar 05, 2013 | Wild Planet Spy Gear Long Range Walkie...
Walkie talkies were working yesterday (gift from Christmas) and today the red power light is on indicating both working, but we can only get sound out of one of them.....any suggestions? brand new...
These walkie talkies are pretty simple to use. Turn on and turn the volume up and talk. So if you turn it on it is possible for there to be enough juice in the batteries to make the LED function but not enough to modulate (or talk) to the other walkie talkie. Have you tried to replacing the batteries with new ones yet? Sometimes recharge ables go bad and they are no good when you install them into your item. So make sure the batteries you installed are "new." And replace in both units. Should this not work, given the nature of the item and the age of those who will more than likely be using them, they break and soldier joints come loose. The back has a screw that is a specialty tool to remove. Outside of removing that and taking a look there is not much that can be done. Make sure to put at least 5 feet between the two radios to allow for good reception.
Regards, Tony
Apr 17, 2011 | Digital Blue LEGO Walkie Talkies
Do u have instructions for the sakar text messenger walkie-talkie ichat?
My kid had one of those and TRUST me its not worth it they last about1 or 2 min
Feb 06, 2011 | Sakar Cyber Gear Slide Click Text...
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Need assembly instructions
Call 1-800-872-6765, and they will email it to you. They just sent it to me in about 5 minutes.
Apr 26, 2009 | Kid Riffic Toys Kidriffic Jump Smart
Toys Logo
258 people viewed this question
Top Kid Riffic Toys Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kid Riffic Toys Toy Expert? Answer questions, earn points and help others
