My HP 1050c sprung a leak all over my floor! My tech came and replaced tubes. Is there something I can do to prevent having to replace my flooring again?
  • A Miller Aug 23, 2010
    get rid of the printer? put it in a tub? what kind of flooring did you have that your printer ruined? you really need new flooring ...
  • 490 Answers
Your local hardware or appliance store sells a short-rimmed plastic tray for setting a clothes washer in. The footprint is not too large and would contain any future spills. Hope this helps:)
Posted on Aug 23, 2010
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
Designjet 1050c system error 0A0050
0A0050 indicates a leak in the tube system has been detected. Can be caused by condensation, but more likely the tubes are leaking and need to be replaced.
Sep 01, 2014 | HP DesignJet 1050c plus InkJet Printer
I keep getting System Error 0A0000 00000002
The error indicates low air pressure to the ink supply station. There is either a leak or the Air Pressure System (APS) is bad. Check for ink inside the rear door to the Ink Supply Station (ISS) and at the print head locations at the carriage.
If there is ink leaking at the ISS, replace the ink cartridge that is leaking. If there is a leak at the print head, replace the ink tube system. If there are no leaks, replace the APS. See the following link for parts: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 14, 2010 | HP DesignJet 1050c InkJet Printer
HP 1050c....Hi, i am getting error on display for
Are you using HP factory new cartridges or some third party cartridges or even wores a refilled cartridge?
80% of the time, that's the cause of the failure.
Don
Feb 24, 2010 | HP DesignJet 1050c plus InkJet Printer
Cyan ink discharge at the back of the ink crtrige.
The leak is from the cyan ink cartridge or from the connections in the ink tube system. Replace the ink cartridge first. If that does not fix the problem, replace the ink tube system.
Jan 13, 2010 | HP DesignJet 1050c InkJet Printer
Leaking moonroof onto passenger floor
There are gasket replacement kits at local auto parts stores. It's time consuming but well worth it. Prior to starting, inspect the tracks with the moonroof open. There's a chance you have a burr or some other kind of obstruction in the track preventing the roof from properly closing/sealing. A 3 year old vehicle really shouldn't leak from a worn gasket but if the gasket were defective it's possible.
May 09, 2009 | 2006 Land Rover LR3
Water accumulates on the floor in the passenger rear
your heater core is going out on the car...its leaking water into the car
Jan 28, 2009 | 1991 Lincoln Town Car
1992 lumina smokes out of heater, consumes more gas
your heater core has probably sprung a leak.does the smoke smell kinda sweet?....check the floor in the front where the floor mats are for moisture or even puddles of antifreeze.(the replacement of a heater core can be very expensive as the entire dash usually needs to be removed to access the heater core)also look under the engine near the firewall for antifreeze drips.
Dec 29, 2008 | 1992 Chevrolet Lumina
Print head failures HP 1050c
the tube system has an air leak causing a dryfire situation. air + printheads = damaged printheads. most users replace the black printhead more often than the colors. the seal where the printhead feed pin fits into the carriage is the end of the tube system. the hole in the seal becomes to large and doesn't properly seal the air out. order the tube system. complete and concise instructions are included in the box for tube replacement. this is considered an end user replaceable part. good luck! please rate this!
Sep 23, 2008 | HP DesignJet 1050c plus InkJet Printer
k24674
