Question about Dishwashers
I rinse my dishes off before I put them in the dishwasher so since they look clean to begin with, I don't know if the dishwahser is working at all. The only thing I know is it sounds like it's running through the cycles, the detergent cup is empty afterwards, but the dishes are covered with foamy suds. Please help!
  • 128 Answers
You might be using the wrong detergent use cascade
Posted on Aug 23, 2010
Our dishes are not being cleaned well with residue left on plates and cutlery and the light next to the rise aid is on at the end of the wash
I have had the same problem a time or two. Make sure that you don't overload the dishwasher and nothing is blocking the spout where the water comes out. Also if you haven't done so already, you may want to add some detergent to the pre wash. Make sure you have enough detergent for the regular wash cycle also....Hottest water possible (at least 140 degrees F). If all that doesn't help, try cleaning them on heavy wash. Check to make sure the rinse aid level is still full. I have also found it easier if you rinse the dishes or cutlery off before putting them into the dishwasher.If none of the suggestions work I say changing your dishwashing detergent and/or rinse aid.Good Luck!
Sep 08, 2011 | Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Food remains on my dishes after a cycle. my dishes just won't get clean. I feel the water temp is hot. I'm thinking maybe I need to clean out the food trap (if there is such a thing) but I don't know...
Well, this is kind of a big job. you need to disassemble all around the pump and clean screens. Also, clean discharge ports on the spray arms.
Really, dishwahsers do a poor job of removing food, and so plates should be pre rinsed.
Oct 15, 2010 | Whirlpool Dishwashers
Dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Dec 17, 2009 | GE Dishwashers
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishes not clean, water spots
You might have really really hard water which would leave mineral deposits on your dishes,,, something could also be blocking the wash arm from rotating, or the water from shooting out of the wash arm which would result in very poor cleaning results
Mar 12, 2009 | Dishwashers
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher leaves film on dishes
make sure your rinse agent aka : Jet Dry is full and water is hot enough.
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Our GE dishwasher does not seem to be rinseing the dishes very well, can you help? thank you
many things can cause washabilty issues: check drain line for high loop it should not go down right out of the garbage disposal it should go up first, too much soap and too clean of dishes at the beginning leaves soap residue,if you clean or rinse the dishes well before you even load them back way off on the soap.
Apr 25, 2008 | Dishwashers
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
