Euro-Pro EuroPro Shark Navigator Vacuum Logo
Posted on Aug 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the reset button on shark navigator. vacuumed throw rug, and bar wont move
Roger Potts
Level 3:
  • Master 694 Answers
  • Posted on Aug 23, 2010
Roger Potts
Master
Level 3:
Answers
694
Questions
0
Helped
220449
Points
1873
I'm not sure it has one. Check the owner's manual though.
Try this. Turn off vacuum. Unplug it. Make sure there are no clogs in main hose, power head intake tube, or intake inside tank. Plug it in, turn it on, and let us know what happens.
lsprd777
Level 1:
  • Contributor 3 Answers
  • Posted on Jun 15, 2018
lsprd777
Contributor
Level 1:
Answers
Questions
Helped
14338
Points
5
Shark steam mop won’t change settings!!!!
Shark Navigator Lift-Away Upright Vacuum. Where exactly is brush bar reset button on shark navigator please?
Question edited for clarity and correct name of the vacuum.
Where is the shark vacuum brush bar reset button? You can find the shark brush-bar reset button on the underside of the vacuum.
Jul 12, 2020
Is Your Shark Vacuum Brush Not Spinning? This Is Why!
Dyson vacuum
Customer service or take a day & take it all apart clean it
I need a DIY solution because my shark navigator lift away beater bar attachment stops working intermittently
If you've gotten 4 years out of a Shark you've already beat the system. Give yourself a pat on the back, throw it in the nearest dumpster, then go to your local vac shop and purchase a quality USA made vacuum cleaner that is repairable and will likely last 20-30 years. Chinese vacs are designed to last one year and parts are not made for Sharks.
1helpful
2answers
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Beater stopped. cant get base plate off to get to belt. please advise.
Sharks are not made to be repaired. They are built to throw away. No parts are made for them for this reason. Save yourself some grief and don't buy another one.
Shark rotator reset button
If shut off may be motor heated when it cools it should start buy its self
Shark navigator vacuum
IF it is belt driven brushes, replace the belt. If not then the motor is most likely bad.
Aug 25, 2013 • Vacuums
Does the shark professional vacuum have a reset button?
Hello, this is Ava with Think Crucial
Your Shark model has a thermostat reset feature. If motor should overheat, the thermostat shuts off the power. The link below is the User's Manual for your Shark Vacuum which includes resetting your unit.
Shark NV22 Owner Manual Maintenance
You can purchase a wide variety of high quality Shark replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Shark
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Top Euro-Pro Vacuums Experts
ZJ Limited
ZJ Limited
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
