I replaced my old mercury thermostat with a honeywell rth2310 and now the compressor doesn't seem to run.
  • 139 Answers
Recheck wires on t stat. white wire to W .yellow wire to Y.green wire to G .red wire to R .or r/c if their is a red jumper wire leave it connected ..good luck
Posted on Aug 23, 2010
Digital thermostat Honeywell RTH 2300 - compressor runs when in heat mode
Check thermostat wires maybe to long and touching in the back of the thermostat
Mar 21, 2013 | Heating & Cooling
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
The backlight is not working on my newly installed Honeywell RTH2310 thermostat.
Hello.The thermostat needs a COMMON wire.The letter C on the back of the thermostat.In the unit it runs there is a COMMON connection for that reason.I hope there is a spare wire strand to use because a lot of thermostats don't need a common to work (uses battery)but honeywell does.
Oct 31, 2010 | Honeywell Focus 6300B 5-2 Days...
I have installed my Honeywell RTH2310 thermostat from an older mercury one properly and it seems to work fine. However, I am unable to get it to operate at the set temperatures. I set the programming to...
Hello Vinny Fear not the thermostat has a built in (factory) deadband of 1 or 2 degrees on purpose to keep the unit from shortcycling.It needs to maintain a minimun run time for the equipment's sake.This is normal and can't be adjusted.
Sep 17, 2010 | Heating & Cooling
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH2310 heating while it's supposed to be cooling
ok to start with if you have a heat pump and not ac over electric heat depending on type but most will be wired as
red to r jumped to rc y to yellow this turns on compressor g to green this turns on fan w to white or brown for electric heat strip or em heat o to orange reversing valve energised in cooling switches from heat to cool or orange to b energised in heating c blue for common
you will have to look at your indoor unit and out door unit to verify what collors the contractor used when they wired it up hope this helps
May 31, 2009 | Honeywell Programmable Thermostat Heater
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
