Question about DCS RDS-364GD-SS Dual Fuel Kitchen Range
Igniter will not go off when starting burners
One burner wont light of the 3
Is the igniter not sparking or is gas not getting to that burner? Have you tried to match light that burner? Those three things is where you start troubleshooting the problem
If the igniter is not sparking, it could be that the igniter is covered with cooking grease or the wire to the igniter has come loose either at the igniter or the igniter module. And simply needs to be reattached (pushed back on).
If the burner won't match light, than it's not getting gas and should be removed and thoroughly cleaned. And while you're at it, remove and clean all the burners and the venturis valves.
Removing the buner burners on a Ducane grill is a bit of a task, so I have included a link to your Owners Manual to assist you. Pay particular attention to the section Annual Maintenance, starting on page # 28.
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3100_4100_LP_OwnersManual_27010331_101508.pdf
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
May 10, 2011 | Ducane Affinity 3100
I have just replaced all the ignitors and the spark control module on the cook top burners. Prior to this the back burners would cause ignition spark continually when lit. the front 2 burners could be...
first check to make sure all the burner tops are setting correctly on the burner base, if not it will make the flame uneven. the way the igniter works is once they feel the flames on them they will stop sparking. make sure the flames are not too low and they are touching the igniter. check them one at a time. if you have any questions message me back thanks
Apr 08, 2011 | Viking Kitchen Ranges
Hi I have a pitco sg14 fryolator. At the time of firing off main burner there is a false ignition at start of heating cycle of oil in tank and there is a woosh sound that shakes front door so basically the...
for the latest design of pitco frialator, the manufacturer added what they called the self-cleaning burner system.during start-up, ignition is delayed so that dust accumulating in the burner face will be removed once the gas build up on burner chamber ignites, it creates a weak explosion like sound.the next time you hear that during start up, the unit is cleaning its own burner, no need to worry.
Mar 28, 2011 | Pitco Frialator SG14 Deep Fryer
Have trouble starting gas burners on nobel fse90-1. Is there a trick to starting the burners. I need serious help before I go mad!
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | Cooktops
One front burner ignites but the igniters continue to spark. when all other burners ignite the igniters immediately stop sparking. this problem started right after spilling some water on burner.
I would make sure you have wiped up all the water you spilled, You may need to take the burners off the stovetop and make sure the tiny little pinholes for the gas to come out are fully dry, Than re-assemble everything and try again.
Jun 06, 2010 | Cooktops
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
Gas kitchen range
Most problems with gas ranges have to do with the flame--either it isn't quite right or it's nonexistent. Most new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners. If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
DCS RDS-364GD-SS Dual Fuel Kitchen Range Logo
77 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
