Question about Maytag MDE308DAYW Electric Dryer
When you push the button to start, the dryer only hums. The dryer is only 2 years old.
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Aug 23, 2010
dididsaythat
  • 291 Answers
SOURCE: Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Posted on Sep 17, 2007
jumptrout51
  • 3361 Answers
SOURCE: start button humms when pushed won't start dryer
Typically this would be a bad motor.
Remove the front panel and drum. Clean any lint from the motor, check the drum rollers for easy movement. Check the belt tension roller for free movement.Check the blower wheel for lint blockage.
If all these check OK and it still will not run it is a bad motor.
Posted on Mar 23, 2009
SOURCE: My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Posted on Apr 11, 2009
  • 58 Answers
SOURCE: My dryer stopped working yesterday. When I press the button to start the dryer it hums, but it doesn't start turning. If I push the button 3-4 times in a row, it hums each time until about the 4th pre
Sounds like the motor is cutting out on its thermal fuse. The only cure is to change the motor.
Posted on May 05, 2009
  • 2290 Answers
SOURCE: The dryer is 8 years old. When I push in the dial
the motor is not turning and that's what is humming,you either have a bad motor,something stuck in the blower usually a sock or the belt is stuck
Posted on Nov 02, 2009
Frigidaire electric dryer. 1.5 years old, stopped turning and only hums when button is pushed
Hello
Is it a pleasant sounding hum, like the sound of a motor running? If so , probably your belt broke.If that hum goes on and on for several minutes, it's definitely belt. Bad motor or start relay, would cut out quickly. Either way ,youv'e got to pull out machine and pull off back to inspect.
Aug 18, 2011 | Frigidaire GLEQ642A Electric Dryer
When I push the button to turn on its making a a humming noise and won't turn on. Its less than 2 years old
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Frigidaire Dryers
My Frigidaire Affinity electric dryer will not start. Its only just over 2 years old. the timer counts down but the drum will not turn nor is there any heat. I've tried jumping the dryer but it still will...
Listen, when you push the start button to hear a low hum, if you do hear this it maybe that your belt is broken. This is an involved job but can be done if you are handy.
Jan 22, 2011 | Frigidaire AEQ6000ES Electric Dryer
Nov 02, 2009 | Amana DLE330RAW Electric Dryer
I have a 2 year old electric whirlpool dryer. When I push the start button, all it does is make a humming noise and won't start.
open the door and hold in the safety off switch, turn on dryer and turn drum by hand. If it tried to move..you may need to replace the belt. If it doesn't move by it's self, then you may need a new motor.
Oct 11, 2009 | Whirlpool Dryers
Hum but wont start
The slight hum you are hearing is the start windings in the motor. This is a common problem in the kenmore dryers and there is nothing you could have done to keep it from happening. the part number on the motor is 279827 and price from sears is $105.99.
Oct 03, 2009 | Kenmore Dryers
Dryer just sits and hums
if you push the start and it just humms it is a bad dryer motor to weak to kick on,to confirm this have sombody hold the dryer door button in and turn the drum when you push the start button,if it jump starts you know it's a bad motor-mike
May 05, 2009 | Dryers
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer
the bearings in the motor are locked up. they are sealed so you have to replace the motor to fix it.
Nov 25, 2007 | Kenmore 62602 Electric Dryer
Sep 17, 2007 | Estate EED4300SQ Dryer
Maytag MDE308DAYW Electric Dryer Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
