Question about Dishwashers
Upper arm won't spin - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Posted on Aug 23, 2010
Spray arm stopped spinning
Which one the upper or the lower spray arm? If the lower is spraying and the upper isn't.. Check the spout pipe to the upper sprayer arm, it is pluged. Or the sprayer arm is wore out around the fitting. GB...stewbison
Aug 31, 2011 | Dishwashers
My dinner plate stops the arm rotating, why? model fdud4812
Both upper and lower washing arms operate on the water pressure and angle of water flowing thru them.
Pressure provided by water pump.
Just about anything that contacts the rotating arm can stop it.
Best thing to do is re-arrange items in dishwasher so that arms can spin freely.
One can always spin washing arms by hand to ensure proper clearance.
Hope this helps...
Jul 30, 2011 | Hotpoint Dishwashers
The upper arm is free spinning by hand, but from all indications, it is not spinning. Water is flowing freely and drain is excellent. Is the upper arm problem a major repair.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 01, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
The top shelf is not getting clean. There is food residue on the glassware that was not there at the start of the wash.
The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back
2. Close the door
3. Start any wash cycle
4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Regards,
BElectric.
Dec 14, 2010 | Frigidaire Professional Series 24 in....
UPPER LEVEL SPRAY DOES NOT SPIN - UPPER LEVEL NOT
plugged spray arm holes, pump intake partially blocked, too little water getting in tub cuz screen in fill valve has debri
Dec 21, 2009 | KitchenAid KUDC25CH Dishwasher
No water pressure in dishwasher
bosch shu5312uc upper spray does not spin. pours water through the center section thus not propelling the arm. any ideas? should the upper arm have any o-rings
Dec 06, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Upper Arm Not Spinning on Whirlpool Quiet Partner I
Possibly, the intake screen under the lower arm is partially plugged. Take the upper arm off and inspect the holes for plugging and that the seam between upper and lower halves is not split. Our Maytag split the same seam--fixed by drilling a number of very small holes along the split and sewing it shut with fine wire.
Aug 08, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Upper arm dose not spin
have you checked to see if the arm spins freely if you push it
Apr 13, 2009 | Beko 24 in. D3421F Free-standing...
Figidare dishwasher
It seems other posts were correct - The upper arm doesn't spin all the time. Once I learned that, and let the dishwasher cycle through, I saw that the upper arm does spin. So, there wasn't a problem with the upper arm afterall. That doesn't solve my crusty dishes problem, but that may have something to do with the soap we're using. We're going to try changing that next.
Dec 27, 2008 | Dishwashers
Dishwashers Logo
154 people viewed this question
Top Dishwashers Experts
