Question about Frigidaire FAA068P7A Air Conditioner
Hello, I have a Frigidaire Air Conditioner (Model Number: FAA067P7A1). It just started to beep randomly. Not all the time. Any reason why ? The filter on the front is clean. Not sure what else to look at ? Thanks, Andy
4 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: I have a Frigidaire FAM18ER2A Window Air
May be rat or squirrel trapped in fan blade. Remove the a/c and water wash and re fix it.
Posted on Dec 02, 2010
  • 251 Answers
SOURCE: MY frigidaire Air Conditioner model
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
shastalaker7
  • 1515 Answers
SOURCE: Hello! My Frigidaire FAH086N1T Thru-Wall/Window
Hi, it sounds to me like you are loosing this motor. Normally when a blower motor fails, which in your case you have a dual shaft motor which also cools the outdoor coil, the condenser, and blows cool air indoors. If it started blowing smoke inside and you smelled an electrical smell, it was either the motor has a burned spot on the armature from dirt or age. If the motor seems to be running ok, try switching it to cool to see if the compressor is working, and do this to all positions on the selector switch. Wait about 5 minutes in between. If all is working properly, its only a matter of time before the motor fails completely. I would run it until it dies out. There are many safetys on the unit, so you are in no danger of a fire when it fails, it will just make noise and freeze up. You will save money if you replace the complete unit and not the motor. If you call out a tech they will remove it and take it to there shop to make repairs charging you by the HR, and this will add up including the cost of the dual shaft motor.Please take my advice as I have had to do this many times before.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Ps, Please keep me posted and be kind in rating any help I have been to you? Thank you!!
Posted on Aug 28, 2011
I have a Frigidaire split system a/c with error code E1. What does this mean?
Hello friend, thank you for your post!
I understand that your Frigidaire split air conditioner is displaying an error code of E1 and you would like to know its meaning. In order to assist you further I would need to have the model number of your air conditioner. With that information I would be able to further assist you. -Matt
Apr 14, 2016 | Frigidaire Heating & Cooling
WHY DOES MY FRIGIDAIRE AIR CONDITIONER SLEEP BUTTON KEEPS BEEPING?
I appreciate your post, Tamara Brazile!
I see that your sleep button on your Frigidaire air conditioner continues to beep. Do you see any error codes on your air conditioner? Additionally, could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the outside frame of your air conditioner or under the front panel. With that additional information I can further assist you. -Matt
Feb 22, 2015 | Frigidaire Heating & Cooling
What is BTU's of this model
Hello Friend, that's a great question!
I show that your post is listed under Frigidaire air conditioner (FAS1084M2A). I show that your air conditioner has a cooling capacity of 18,000 BTU's. If this is not your model number, please provide me the correct number. You can typically locate the serial tag (which lists your model number) behind the front grill by the air outlet or on the side of the cabinet. Other possible locations are on the front edge of the chassis base or behind the dial plate of the control panel. If you need further assistance, please feel free to reconnect.
Jul 11, 2014 | Frigidaire FAS184M2A Air Conditioner
Need a manual to download for model FAH0818R1T
Good Morning Friend, this is Z. I am happy to assist you!
I see that you are looking for the manual of your Frigidaire air conditioner, FAH0818R1T; however, it appears above-listed model number is invalid. The serial, which lists your model number, is typically located behind the front grill by the air outlet or on the side of the cabinet. In the meantime, I have located the Owner's Guide to a similar air conditioner, model number FAH08ER1T1. Looking forward to hearing from you. Thank you!
Frigidaire Manual Search Results
Jun 15, 2014 | Frigidaire FAH086R1T Thru-Wall/Window Air...
Why incessant beeping?
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FRA124HT2, begins with a constant beeping, and changes the modes itself, about every 30 minutes. I also see that it ends up on a different setting each time it does this. I suggest resetting your air conditioning, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Bring power back to it and turn it on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRA124HT2 12000 BTU...
How to stop my Frigidaire 15,100 BTU from beeping
Hello Naomi - Thank you for your question. When the air conditioner is beeping, it may be a warning sign that the filter needs to be clean or that you need to reset the unit. The LED (light) will illuminate and beep after 250 hours of operation. After cleaning the filter, you may reset the "FILTER RESET" option by simply pressing and holding down the button for approximately twenty seconds and the light/beeping will go off. However, if you have done this, try pressing the "RESET" button on the GFI plug of the unit. Wait approximately 2-3 minutes and then turn on the air conditioner. If issue persists, then at this point I would suggest reaching out to the manufacturer directly to see if you have any limited warranty on the appliance or you may alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area.
Jun 14, 2013 | Frigidaire 15,100 BTU Heavy Duty Window...
Not starting
Hello Pete T - From what you have described the air conditioner possibly have a defective power/control board or faulty plug. I would suggest contacting a professional to accurately diagnose and repair the unit.
Oct 02, 2012 | Frigidaire 15,100 BTU Heavy Duty Window...
Air conditioner keeps beeping when on
My little Frigidaire (5 or 6k btu) beeps intermittently and is really annoying. I never know whenn it's going to happen.
Aug 13, 2008 | Frigidaire FAC084N7A Air Conditioner
Frigidaire FAA068P7A Air Conditioner Logo
88 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
