Question about Refrigerators
Just installed new built in side by side integra 800 fridge / freezer. Freezer works find, the fridge has all the lights on but does not cool at all. Ran the diagnostics and I got a quick flash of "load 1", "load 2" and "load 3". The 800 number doesn't work on week-ends. Any ideas?
  • 3 more comments
  • David Carr May 04, 2008
    the error message is actually load 1, load 2 and load 3, very quickly
    Just to confirm, I have run the diagnostics again and the error message is "Load 2"
    the system was professionally installed and given the freezer works and the internal lights etc. on the fridge work I have to assume it is wired in correctly. No chance it is a setting I have overlooked?
    It is a Bosch B30IR70NSP/03, 2008, type K1SDR3OUS. New, first time turn on. The mating freezer unit works fine, bothe professionally installed. The error message is Load 2
    Thanks, I have tried the above and have the manual. The error "load 2" is what I am getting from the diagnostics, what I don't know is what that means.
  • Refrigerators Master
  • 13,433 Answers
Hello dcarr
Can you provide me with more detailed information about your products.
Brand?
Model?
year?
Type?
Thanks I'l try my best to solve your problem.
Posted on May 04, 2008
  • Ekse May 04, 2008
    Well the device seems to be wired correctly since you can perform these tests and the freezer works.
    Here are the installation instructions
    http://www.bshextranet.com/files/techtoo...
    Here is the product manual
    I went throught the manual looking for a solution, only thing it says there is to give the error code to a tech @ bosch
    Il let you know if I figure it out.
  • Ekse May 04, 2008
    You can reset factory settings by
    Simultaneously hold down the setup and alarm off buttons for 3 seconds
    if the factory settings are reset:
    an appliance which is switched off switches on
    the uspoer function switches off
    settings changes in setup modde are reset to factory settings.
    Sergeant:
    Champion:
  • 427 Answers
If everything is plugged in correctly, then it is probably an internal problem.
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Fridge light on but fridge warm, freezer still working. zanussi built in fridge freezer 3 year old
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Refrigerators
Freezer side works, but refrigerator side is warm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | Jenn-Air 48" Side-By-Side Built-In...
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Turned power to house off, now fridge and freezer not cooling
you have a showroom switch that may have been turned on. it located at the top in the front middle. if that switch is on the lights will work but the motors will stay off
Jul 11, 2008 | Viking 42 in Built In Professional...
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
