Question about Microwave Ovens
I have a slab granite countertop and stainless steel, undermount sink. For some reason, there were no clips installed holding the sink in place, so the sink has now separated from the counter and there's a half inch gap at the front, allowing water to leak into the cabinet below. How can I reseal the sink to the underside of the grantie counter?
  • sschilling04 Aug 23, 2010
    Thanks - any recommendations on where i can purchase that stuff? Any old home depot or do i need to find it at a kitchen and bath retailer?
  • sschilling04 Aug 26, 2010
    Solution is holding fast. Thanks
  • Microwave Ovens Master
  • 43,501 Answers
To repair that I would get some of this....
http://www.sashcosealants.com/Content/Files/lexel_brochure.pdf
Clean both surfaces as much as possible, then apply the Lexel to the gap and prop it up tightly with something and allow it to cure overnight....
This will then hold that sink indefinetly...
heatman101
Posted on Aug 23, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Aug 23, 2010
    I buy it at my local hardware that is very similar to a Lowe's only smaller....
    I would think that if you called around you could find it...
    Never thought to check for it when I've been in a Lowe's or HD...
    Hope you can get it... it has saved my **** a few times...:-)
    heatman101
My microwave works well, but the big problem is that I have to slam the door very strongly too many times for it can be started.
Sounds like that you have some internal problems with the electronics circuits. Please take to someone qualified to work on it, for there are very high voltages inside if you go to the wrong place inside even if your microwave is unplugged it stores voltages.
Nov 15, 2015 | Panasonic NN-SN773S Stainless Steel...
Code on screen H-98 wont run
www.panasonic.com/.../troubleshooting-failure-co
Jun 16, 2014 | Panasonic NN-T945SF Stainless Steel 2.2...
It sparks
Check splatter shield inside cooking area for burnt carbon ie replace
Dec 11, 2013 | Panasonic NNSD688S 1.2 Cu. Ft. Capacity...
Bosch hmt 845k microwave oven
If for some reason you don't still have the installation instructions, their support site should allow you to either download or order a set.
If you can't find their site, try the dealer from whom you purchased the oven.
Jun 09, 2013 | Microwave Ovens
Microwave wont heat
We would need to know the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc.
Please post a new help request with that and more detailed symptoms, such as when it occurs.
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Apr 15, 2013 | Sharp Carousel 1.5 cu. ft. Countertop...
Change microwave power
Which model microwave do you have?
Jan 14, 2013 | Sharp Carousel 1.5 cu. ft. Countertop...
I have a stainless steel sink in my RV. When it was stored for the winter, I used FRI-Z-AIR containers to absorb moisture. Some of the crystals spilled into the sink and actually etched spots into the sink...
I would try SOS pads or even fine sandpaper if necessary. Make sure you go with the "grain" so it isn't obvious afterward. It is possible to blend with those grain lines in stainless steel, we used to do it in a factory.
Aug 04, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
