I have a energy knight ductless mini-split 18000 btu heat pump ash018a that needs the blower wheel cleaned, only problem is how do you remove it or how do you clean it with out removing it?
  • 139 Answers
Use a tooth brush then shop vac or a screwdriver to scrape clean..
Posted on Aug 23, 2010
How to fix H5 error
Ipm is inverter protect. Replace PCB (printed circut board)
Oct 12, 2016 | Gree 18000 Btu 20 Seer Ductless Mini Split...
What kind unit is
This type of unit is called a Mini Split Air Conditioner.
Hope that helps you check us out at Air Duct Cleaning
Nov 02, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
R22= 70-80psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Error code u5
AC current detected circuit malfunction.
Jul 06, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
My aircon is not blowing
Most liekly needs to have freeon added to the system, if that doesn't help its propely a problem with the electric motor on the blower.
Nov 07, 2012 | Gree 9000 Btu 23 Seer Ductless Mini Split...
Heating & Cooling Logo
450 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
