Question about LG Computers & Internet
LG screen won't trn on. I have checkd the power source, no light showing at all on the monitor.
  • 11,361 Answers
You need to go inside and check the main fuse, rectifiers, MOSFET, caps, etc,
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 23, 2010
My lg monitor screen is black. It powers on but no picture or light. What could be wrong?
Several things, it could just be turned down real low but most likely it is not getting a signal from the source. What color is the light on the bottom. If it is not green you have an input signal problem.
Aug 13, 2014 | LG 22" FLATRON LCD Monitor
What electrolytic capacitors need changing on a LG W2242S
Start with any which are showing any signs of doming or bulging and any near a source of heat. Use height temp replacements.
Jul 18, 2014 | LG Computers & Internet
Forgetting that the computer was on, I went to turn it on and shut it off while in sleep mode. The screen won't work.
A monitor does not normally save any states such as sleep. If unplugging the monitor from the power source for ten to twenty minutes and re-plugging it in does not fix the problem check and see if the monitor's menu comes up.
Even in sleep mode, the menu for the monitor should show. If it does, try resetting the monitor to factory default settings. If the menu does not show up, then there is an issue with the monitor.
Jul 04, 2012 | Dell Computers & Internet
How do i clean lg flatron W1952TQ screen?
According to the Owner's Manual (http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=W1952TQ-TF.AUSMAPN&matchedModelCode=1000004017&searchEngineModelCode=W1952TQ&initialTab=documents&targetPage=support-product-profile#), unplug it from its power source, then wipe it with a slightly damp (not wet) cloth; & don't spray the screen with an aerosol because the overspray could cause electrical shock. I suggest that with it unplugged from its power source, use monitor wipes (available at most office supply stores). Then plug it into its power source away from souces of water, & you're done.
Oct 12, 2010 | LG Computers & Internet
The green light indicating power is blinking on and off and nothing is showing up on the screen.
when the green light is flashing it means it's not getting a signal from the computer..
1. try toggling through available sources with the source button on the monitor.
2.check all cables leading from the pc to the monitor.
Apr 02, 2010 | LG Flatron L1718S LCD Monitor
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
I have an LG flatron l1710s monitor . when you turn it on it flashes the message that there is no video signal then the screen goes black. and nothing is showing. the monitor stays on as far as the power...
You need to 1. hook up and 2. select a video source. It can be from your antenna, cable, tuner, VCR, DVR, DVD, etc.
If you have any of these connected properly, 2. select the correct input to get any video to work.
See your operator's manual for set up instructions or ask me for more information about the hook up.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Computers & Internet Logo
80 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
