Question about Frigidaire FAC107P1A Wall/Window Air Conditioner
Frigidaire Air Conditioner (Model Number FAA067P7A1) randomly beeps. Why ?
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 659 Answers
SOURCE: No installation manual for new air conditioner
Here you go...........
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FAS257S2A&User=&Search=Search
Posted on Mar 31, 2009
alex_salve
  • 78 Answers
SOURCE: goldstar model number wg1205r AIR CONDITIONER, NOT COOLING
thermal relay is not functioning , u need service technician
Posted on May 17, 2009
SOURCE: Electronic control on Frigidaire air conditioner not working
which one take live or nuetral ?
common
start
run
thanks
Posted on Jul 11, 2009
  • 251 Answers
SOURCE: MY frigidaire Air Conditioner model
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
How to plug up sensing element
Thank you for your post, Inez!
I understand you would like to know how to plug up the sensing element inside of your Frigidaire air conditioner. In order to further assist you may I have your model number? You can locate your serial tag (which lists your model number) on the side of your air conditioner. With that information I can further assist you. -Matt
May 16, 2015 | Frigidaire Heating & Cooling
WHY DOES MY FRIGIDAIRE AIR CONDITIONER SLEEP BUTTON KEEPS BEEPING?
I appreciate your post, Tamara Brazile!
I see that your sleep button on your Frigidaire air conditioner continues to beep. Do you see any error codes on your air conditioner? Additionally, could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the outside frame of your air conditioner or under the front panel. With that additional information I can further assist you. -Matt
Feb 22, 2015 | Frigidaire Heating & Cooling
How too separate from cabinet?
Hi Friend, I am happy to help you!
I see that your question is listedunder Frigidaire air conditioner and that you are looking for information on how to separate your air conditioner from its cabinet. May I have your model number please? The serial tag, which lists your model number, is typically located behind the front grill by the air outlet or on the inside of the cabinet. Other possible locations of the tag on room air conditioners are on the front edge of the chassis base or behind the dial plate of the control panel. If you have a split air conditioner, try checking on either the front or outer appliance on the right side of the cabinet. Hopethis helps and I look forward to your response. Thank you! - Z
Jul 24, 2014 | Frigidaire FAS257S2A WallWindow Air...
What is BTU's of this model
Hello Friend, that's a great question!
I show that your post is listed under Frigidaire air conditioner (FAS1084M2A). I show that your air conditioner has a cooling capacity of 18,000 BTU's. If this is not your model number, please provide me the correct number. You can typically locate the serial tag (which lists your model number) behind the front grill by the air outlet or on the side of the cabinet. Other possible locations are on the front edge of the chassis base or behind the dial plate of the control panel. If you need further assistance, please feel free to reconnect.
Jul 11, 2014 | Frigidaire FAS184M2A Air Conditioner
Need a manual to download for model FAH0818R1T
Good Morning Friend, this is Z. I am happy to assist you!
I see that you are looking for the manual of your Frigidaire air conditioner, FAH0818R1T; however, it appears above-listed model number is invalid. The serial, which lists your model number, is typically located behind the front grill by the air outlet or on the side of the cabinet. In the meantime, I have located the Owner's Guide to a similar air conditioner, model number FAH08ER1T1. Looking forward to hearing from you. Thank you!
Frigidaire Manual Search Results
Jun 15, 2014 | Frigidaire FAH086R1T Thru-Wall/Window Air...
Why incessant beeping?
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FRA124HT2, begins with a constant beeping, and changes the modes itself, about every 30 minutes. I also see that it ends up on a different setting each time it does this. I suggest resetting your air conditioning, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Bring power back to it and turn it on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRA124HT2 12000 BTU...
What is the serial number for fra256st2 frigidaire window air conditioner
Unfortunately, there is no way to know the individual serial number of each Frigidaire AC unit, as they are all different. Even the manufacturer, couldn't tell you the exact serial number from the model number, alone.
Hope this helped answer you question and thanks for choosing FixYa.
Aug 22, 2011 | Frigidaire FRA256ST2 WallWindow Air...
Remove Front panel for cleaning. Frigidaire FAC127P1A4 Air conditioner
Need a part number for a "drain pipe" that would fit in the bottom of the drain pan so I can redirect condensate for Frigidaire Air Conditioner, model FAS257Q2A
May 11, 2009 | Heating & Cooling
Air conditioner keeps beeping when on
My little Frigidaire (5 or 6k btu) beeps intermittently and is really annoying. I never know whenn it's going to happen.
Aug 13, 2008 | Frigidaire FAC084N7A Air Conditioner
Heating & Cooling Logo
137 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
