Question about Cameras
When i turn my camera on it displays an error message "turn the power off and on again" when i turn it off and back on - it shows the same message
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 23, 2010
Not working always show "turn thepower off and on
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Aug 01, 2011 | Sony Cybershot DSCW310 Digital Camera
My sony Camera (DSC -W110) is showing "Turn the power off and on again" while switch on the camera,it appers again & again after switching the camera on and off
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Also tryinitializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settingsSub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Mar 21, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
Lens is in projected conditon, turn power off and on again shows in the display
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Mar 06, 2011 | Sony Cyber-shot DSC-W300 Digital Camera
When i on the unit it shows turn the power off and on again
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 19, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
On the screen shows turn off and then turn on again and again-it does not turns on any way
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa.
Jan 17, 2011 | Sony Cyber-Shot DSC-W7 Digital Camera
Shows turn the power on and off and access
Turn on the camera.
Thanks,
KenSolutions
FixYa
Jun 15, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Error message when turned on
Turn on the camera.
Apr 27, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
Turn the power off and on again message
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Showing turn the power off and on again.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu under Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
Oct 19, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
When I turn my Sony Cybershot 7.2 mega pixel camera on, the lens keeps going in and out and the message "Turn the Power on and off again" shows up on the LCD screen. When I turn the power off and on again,...
Turn on the camera.
Thanks,
KenSolutions
FixYa
Dec 06, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Cameras Logo
110 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
