Question about Samsung Televison & Video
SAMSUNG VP-L300 VIDEO CAMERA. PLAYS RECORDING BACK IN VIEW FINDER PERFECTLY. WHEN PLAYING BACK ON TO TELEVISION PICTURE IS UNSTEADY. TRIED CLEANING HEADS WITH DRY CLEANING TAPE WITH NO IMPROVEMENT. PROBLEM HAPPENED AFTER NOT USING CAMERA FOR SEVERAL MONTHES. THANKS, GEOF
SOURCE: no picture
Go to the manufacturer's website, for Canon it is <a href="http://www.usa.canon.com/consumer/controller?act=SupportIndexAct">http://www.usa.canon.com/consumer/controller?act=SupportIndexAct</a>
Select your device, and click the button for camcorder product advisories. There has been a known problem with the CCD chip in certain models, if that is the problem Canon will repair the problem free of charge, even without being under warranty. Free shipping as well.
Posted on Feb 20, 2008
  • 301 Answers
SOURCE: Fuzzy Picture when souce is not HD
sounds like you may have a problem with the digital scan card or next hyper module. i suggest calling your neighborhood tv repairman
Posted on Mar 31, 2008
SOURCE: Samsung LE32R7 Picture Flashing
I have a 37"Samsung LCD and having just spoken to the Sky engineer (also a friend) he says it is a national problem between Sky+ and Samsung. I have the same problem when on playback but not on real time? If you had your box changed to an Amstrad what sort did you have the problem with?
Posted on Apr 21, 2008
SOURCE: pink or grey horizontal lines on video download or viewing
I have the same issue and have for over a year (haven't had the time to send it to Canon for a few weeks to analyze, but have cleaned it numerous times). But I can tell you that the problem is internittent and the recordings are fine. Eventually, don't know the remedy, but it will suddenly stop doing that and I can download fine, and watch on camera fine. When it does happen, I just keep recording. It never shows up permanently. I re-tyr downloading or viewing and about the 3rd or 3th time (let it sit for a few hours between) it is normal!
Posted on Aug 22, 2008
  • 55 Answers
SOURCE: have a samsung Samsung LE26A456C
What is it that you are trying to record? If you are trying to record a DVD you have purchased onto a DVD-R, you will almost always run into a problem because most purchased DVDs have copyright codes burned into them, making them unrecordable. Most VHS tapes have these copyright protection codes in them as wel. If you are trying to record a television show, and are unable to do so, make sure that the DVD that you are using is compatible with your burner. If your burner is set up to record only DVD-R, then you must use only the DVD-R discs. If your burner is set up to record only DVD+R, then you must use only the DVD+R discs. Some burners will record both the DVD-R and DVD+R. If you have the right discs for your burner, make sure that the discs are correctly formatted to be recorded. Also, make sure that if you are recording from a cable box or other input that you have the correct unput channel selected on the burner. If these suggestions don't work, then it could be the brand of DVD that you have purchased (i.e. Sony,Maxell,TDK,Fuji,etc.). Check your manual for acceptable brands. I hope this helps you out. Let me know if I can be of further assistance.
Posted on Sep 08, 2008
Fast tape playback for samsung vp-l770 can't watch at normal speed on camcorder?
Tapes recorded on one camcorder very rarely play back satisfactorily on another machine - you will have to use your old camcorder to view them, or else get them transferred to DVD
Oct 07, 2016 | Samsung VP-L770 Hi-8 Analog Camcorder
Samsung vp d20 camcorder
MiniDV cameras have two video heads on the rotating drum, which read and write the picture in broad horizontal bands. When one head is not working, normally because it is clogged by dust/dirt/tape residue, you see broad bands of noise across the image occupying exactly half the total image area.......
Aug 22, 2008 | Samsung VP-D20 Mini DV Digital Camcorder
Samsung VP D31 stopped recording video - just black screen
my samsung vpd230 has stoped recording, just a black screen,
would you also explain what a ccp is,also the words memory stick keeps keeps appearing.thankyou
Apr 06, 2010 | Samsung VP-D31 Mini DV Digital Camcorder
No picture on LCD screen
Flex wire connecting LCD to the camcorder is broken. I bought it in the repair shop and did it by miself. it's very common problem
Good luck
Meggita
Aug 25, 2009 | Samsung Compact MiniDV Digital Camcorder
Samsung VP-D305i picture is light and blurry night vision good
For a manual, try Googling (Samsung)(VP-D305i)(manual) without parens.
Jan 02, 2018 | Video Cameras
Sound but no picture.
if you are able to playback previously recorded cassette and the picture is perfect then its not the head. then the problem is with the image grabbing section i.e. the CCD. May be its damaged and needs replacement.
Jan 19, 2008 | Video Cameras
No PLayback sound
check the microphone of the camera if it has a feedback on the television..if there no feedback the microphone of the camera is not working
Aug 05, 2007 | Samsung VP-DC161 DVD Camcorder
Video playback
may still need to be cleaned andy.Sometimes cleaning tapes wont get the dirth out.This is more than likely what is wrong.How old is cleaning tape you tried may be time to try new cleaning tape,.
May 21, 2007 | Samsung VP-W70U Camcorder
Televison & Video Logo
97 people viewed this question
Henry  Thomas
Henry Thomas
